05-01-2019, 11:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | oppo a37m boot fail Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM129) MODE : BOOTROM PORT : 129 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM129) MODE : BOOTROM PORT : 129 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : Oppo : A3 | Manual : Disabled BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM129) MODE : BOOTROM PORT : 129 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
