04-01-2019, 02:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | qualcore 1023 3g not spdt not detect Start at : [31-03-2019 / 21:33:05] Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:33 Reconnect Power/Cable! Finish at : [31-03-2019 / 21:33:39] but after all gmail account still on..then y try to flash: Card found: S/N : 8CD632DE , v0137 Chinese Miracle II [SPD module] v 1.24 Loading : S1087A_7.0_YK17101020_XC_OV-qualcore_1023_3G_171027_V1.3.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : S1087A_7.0_YK17101020_XC_OV-qualcore_1023_3G_171027_V1.3 FastCheck : 0x00AD361750 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128_AndroidM.dat File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : tos.bin File : vmm.bin File : recovery.img File : system.img File : persist.img File : userdata.img File : new_logo.bmp File : logo.bmp(1) File : cache.img File : sysinfo.img File : u-boot.bin File : SC77xx.xml Load Ok! Start at : [01-04-2019 / 02:26:30] Operation : Flash [ v1.24 ] Start at : [01-04-2019 / 02:26:31] Operation : Flash [ v1.24 ] but seems that tab kent use sci 2serial..only as DriverCoding usb composite bus ...how ken y revive tab?? its on black screen??? |
04-01-2019, 10:14 | #3 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | combination key e volm- and connect cable..but instaling drivers SCIUSB2SERIAL notwork at all...windows say incompatible etc...dont let me install ..only work SPRD MUX PROTOCOL or DriverCoding usb composite bus. Dont now what is possible to make...maybe desoldering battery??and try again?? br |
04-01-2019, 10:20 | #4 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | wen box notmake frp reset y use resardonwload...but software resardownload was not running bar..so y disconnect...and now is like this. original firmware from tab is here: https://ov.overmax.eu/en/product/qualcore-1023-3g/ |
04-01-2019, 10:23 | #5 (permalink) |
04-01-2019, 14:36 | #7 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | sir.JayDi..y press reset boton and tablet is wornking normaly..but still kent reset gmail account,here´s log: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! y chose sc77xx model select br |
