12-26-2021, 18:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | Motorola XT-2097-7 SP unlock I'm unable to unlock Moto XT-2097-7 or even identify the device in all modes using CM2MT2, here is log using flash mode: Code: Operation : SP Unlock [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM106) MODE : PRELOADER PORT PORT : 106 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM (Android) (COM106) MODE : PRELOADER PORT PORT : 106 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Code: Operation : SP Unlock [ v2.32 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM106) MODE : PRELOADER PORT PORT : 106 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Tue Sep 14 15:43:58 CST 2021 AP_SWVR : alps-mp-q0.mp1-V9.135_ontim.q0mp1.k61v1.64.bsp_P16 Error : Modem didn't started! Unlock not possible! Error : SPLock identification failed! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! |
12-26-2021, 20:00 | #2 (permalink) |
Member: 2119579 Status: Offline Thanks Meter: 44 | Here is flash tool configuration: Code: <?xml version="1.0" encoding="UTF-8" ?> <flashtool-config version="2.0"> <general> <chip-name>MT6765</chip-name> <storage-type>EMMC</storage-type> <download-agent>SP_FLASH_TOOL_DIR\MTK_AllInOne_DA-Malta-md.bin</download-agent> <scatter>RECOVERY_FILE_DIR\MT6765_Android_scatter.txt</scatter> <authentication></authentication> <certification></certification> <rom-list> <rom index="0" enable="false">RECOVERY_FILE_DIR\preloader_malta.bin</rom> <rom index="16" enable="true">RECOVERY_FILE_DIR\logo-verified.bin</rom> <rom index="17" enable="true">RECOVERY_FILE_DIR\md1img-verified.img</rom> <rom index="18" enable="true">RECOVERY_FILE_DIR\md2img-verified.img</rom> <rom index="19" enable="true">RECOVERY_FILE_DIR\md4img-verified.img</rom> <rom index="20" enable="true">RECOVERY_FILE_DIR\md5img-verified.img</rom> <rom index="21" enable="true">RECOVERY_FILE_DIR\md6img-verified.img</rom> <rom index="22" enable="true">RECOVERY_FILE_DIR\md7img-verified.img</rom> <rom index="25" enable="true">RECOVERY_FILE_DIR\md1dsp-verified.img</rom> <rom index="26" enable="true">RECOVERY_FILE_DIR\spmfw-verified.img</rom> <rom index="27" enable="true">RECOVERY_FILE_DIR\scp-verified.img</rom> <rom index="28" enable="true">RECOVERY_FILE_DIR\sspm-verified.img</rom> <rom index="30" enable="true">RECOVERY_FILE_DIR\lk-verified.img</rom> <rom index="31" enable="true">RECOVERY_FILE_DIR\boot.img</rom> <rom index="32" enable="true">RECOVERY_FILE_DIR\dtbo-verified.img</rom> <rom index="33" enable="true">RECOVERY_FILE_DIR\tee-verified.img</rom> <rom index="34" enable="true">RECOVERY_FILE_DIR\vbmeta.img</rom> <rom index="35" enable="true">RECOVERY_FILE_DIR\vbmeta_system.img</rom> <rom index="36" enable="true">RECOVERY_FILE_DIR\vbmeta_vendor.img</rom> <rom index="54" enable="true">RECOVERY_FILE_DIR\super.img</rom> <rom index="59" enable="true">RECOVERY_FILE_DIR\elabel.img</rom> <rom index="61" enable="true">RECOVERY_FILE_DIR\userdata.img</rom> </rom-list> <connection type="BromUSB" high-speed="true" power="AutoDetect" da_log_level="Info" da_log_channel="UART" timeout-count="3600000" com-port="" storage_life_cycle_check="false" /> <checksum-level>both</checksum-level> <!--log_on: log switch, enable log if true, otherwise false; log_path: the directory in which the log files has been stored; clean_hours: the time setting to delete log files regularly, the unit is hours.--> <log-info log_on="true" log_path="C:\ProgramData\SP_FT_Logs" clean_hours="744" /> </general> <commands> <download-only> <da-download-all /> </download-only> </commands> </flashtool-config> |
12-27-2021, 12:01 | #4 (permalink) |
Member: 2119579 Status: Offline Thanks Meter: 44 | Well, I found proper DA file for this model but I wasn't able to unlock it here are logs: Code: Operation : SP Unlock [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA-Malta-md.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501003458364B4D420360C1CE1948BD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 1623313945 ( 0x60C1CE19) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3D54F50533EA77986D5CE5D131758AA5 DA : USB : HIGH-SPEED Boot done! [Info] : Unsupported security type in selected mode! Repeat operation in META mode! INFO : Generating and send report data ... INFO : Report sent! Done! Elapsed: 00:00:17 Code: Operation : Identify [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA-Malta-md.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501003458364B4D420360C1CE1948BD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 1623313945 ( 0x60C1CE19) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3D54F50533EA77986D5CE5D131758AA5 DA : USB : HIGH-SPEED Boot done! Product Brand : motorola Product Device : malta Product Model : moto e(7) Product Name : malta Patch Level : QOLS30.288-39-2 Display ID : QOLS30.288-39-2 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-09-05 Build Time : 14.09.2021 Product Info : malta Display ID : QOLS30.288-39-2 Product Board : malta Board Platform : mt6765 Product Manfct : motorola USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : 0xA108CF31 NVRAM : State : Ok! NVRAM : SecLv : Vendor Signed INFO : WiFi MAC : 441C7FC800DD INFO : BlTh MAC : 441C7FC83B75 INFO : IMEI[1] : 357722570470862 INFO : IMEI[2] : FFFFFFFFFFFFFFF Backup sensetive data [ 17 ] Backup path : Backup\MT6765__3D54F50533EA77986D5CE5D131758AA5\ [15] Read : NVRAM [7] Read : NVDATA [14] Read : PROINFO [6] Read : NVCFG [9] Read : PROTECT1 [1] Read : PGPT [12] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] PRELOADER : DEVICE : DEV : MT6765 NME : preloader_malta.bin CNT : 000B EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON | DEV : S0J9N8 : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 700100474E424C5141 : VEN : KINGSTON | DEV : GNBLQA : RAM : [ 2.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 1501003458364B4D42 : VEN : SAMSUNG | DEV : 4X6KMB : RAM : [ 2.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] EMI : [09] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [0A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_malta.bin Done! Elapsed: 00:00:26 |
12-27-2021, 15:51 | #7 (permalink) | |
Member: 2119579 Status: Offline Thanks Meter: 44 | Quote:
I wiped the device and flashed it again, the device read the network and after restore security files, it got locked again | |
