Old 01-26-2021, 21:02   #1 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
oppo f11 pro cph1969 DEAD AFTER HW REPORT
Card found : 7C446640 , v0147
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.18
Load IDBase v125162 Ok!
Operation : HW Report [ v2.18 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM39)
MODE : BOOTROM
PORT : 39
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Sylvia
TYPE : MODERN RAPHAEL
BROM : MEID : C200DC4C60E4E4901B65F225EF9F415F
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : C28E4D097378EDC8EE8B730BDEE51DC215DDBA5BC1A070E6F0 3E56413CFF8266
BROM : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00007017 : DA SEND ERROR!
ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type!
Info : LEGACY : HW reporting feature unavailable for current device!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Done!
Elapsed: 00:01:34
HWreport : Mode : UFS
MODE : BOOTROM
PORT : 39
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
Done!
Elapsed: 00:00:14
MODE : BOOTROM
PORT : 39
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
Done!
Elapsed: 00:00:08
Operation : Reset Settings/Format FS [ v2.18 ]
Mode : SMART RESET
Old 01-27-2021, 02:34   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
We don't support such CPU and into logs it's not boot
Then how dead ?
Reconnect/charge battery check
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 01-27-2021, 04:29   #3 (permalink)
Member: 1328371
Thanks Meter: 121
Try to Press Volume Up + Volume Down + Power button till phone power on..
Old 01-27-2021, 12:36   #4 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
PTFN : MediaTek USB Port (COM64)
MODE : BOOTROM
PORT : 64
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
first time phone working
now black screen
Old 01-27-2021, 13:12   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
disconnect and reconnect battery
Old 01-27-2021, 15:11   #6 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
i already try this same problem
Old 01-27-2021, 15:41   #7 (permalink)
Member: 2452939
Thanks Meter: 256
Show MTK port in device manager?
Try again with hw report by pressing volume keys and post result.
Old 01-27-2021, 18:52   #8 (permalink)
Member: 2120470
Write extcsd with jtag. Only solution.
Old 01-27-2021, 21:47   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It is CAN'T dead because boot - related only to RAM memory, nothing bad happen with device at all.
If you made some kind of TP - make sure you not burn the board or broke some resistor.
Old 01-28-2021, 05:12   #10 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
oppo f11 pro cph1969 no problem AFTER HW REPORT
i already tested
infinity Team delete this worng posting
Old 01-28-2021, 05:20   #11 (permalink)
sigma xi's Avatar
Member: 773960
Thanks Meter: 529
just do hard reboot it will alive again
The Following User Says Thank You to sigma xi For This Useful Post:
Old 01-28-2021, 08:23   #12 (permalink)
Member: 2439409
Thanks Meter: 104
hello now i chack oppo f11 pro fully dead my phone
here is hw report
Card found : D1298E72 , v0147
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.19
Update configuration ...
Update Ok!
Operation : HW Report [ v2.19 ]
PTFN : MediaTek USB VCOM (Android) (COM8)
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : MEID : 24F82B2DB82DCB001B9F27609AA381C1
BROM : BOOTROM
BROM : SOCID : 6C2B1EA5691634F5DD456937AFBBA7B5E6E132B4EF88BD6E4A C00E61905CC3A8
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0002
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00039000 [ 228.00 KB ]
DRAM: 0x180000000 [ 6.00 GB ]
EMMC: 90014A68444561503303CBA539783681
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hDEaP3
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x1D1F000000 [ 116.48 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 45B13EBF9B0385E7919F20AFDA8588CD
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 90014A68444561503303CBA539783681
MEM : VEN : HYNIX | OEM : 4A01 | DEV : hDEaP3
DAT : Size: 119280 MB, Max.Speed: 52000 kHz, blklen(512), nblks(244285440), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 1000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 150000 ms
Secure trim timeout : 150000 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 600 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 8h
Sleep current (VCCQ): 9h
Sleep/awake timeout : 419430400 ns
Sector count : e8f8000h
Min. WR Perf. (52MH,8b): 8ch
Min. Read Perf.(52MH,8b): 8ch
Min. WR Perf. (26MH,8b,52MH,4b): 46h
Min. Read Perf.(26MH,8b,52MH,4b): 46h
Min. WR Perf. (26MH,4b): 1eh
Min. Read Perf.(26MH,4b): 1eh
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 1h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 15h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 136ah (40714240 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : Not defined
EOL status : Normal ( Less than 80% reserved blocks used )
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:18
any one have firmware please share
Old 01-28-2021, 11:16   #13 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
here is hw report
Update Ok!
MODE : BOOTROM
PORT : 8
BROM : Init BROM
BROM init passed!
CODE : Sylvia
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0002
EMMC:
Boot done!
Memory Info :
EXT_CSD Info :
HPI features : 1h
TRIM timeout: 0 ms
Power class: 0
Card type : 57h
Command set : 0h
HS timing : 0h
Bus width : 0h
Boot bus width : 2h
HPI management : 0h
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
Overall status :
Done!
Elapsed: 00:00:18
i have same problem
i need too firmware
Old 01-31-2021, 15:29   #14 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
help
i need help plz
thx
Old 01-31-2021, 22:36   #15 (permalink)
Member: 2156069
Sonork: Merujeffrey
Thanks Meter: 69
False allegations, maybe you have done some testpoint and messed up the device with other tools... F11 pro, fully tested by me. Even dead f11 pro revived by cm2 by me, tomorrow I will post logs...
The Following User Says Thank You to merujeffrey For This Useful Post:
Page generated in 0.28214 seconds with 8 queries
