07-05-2017, 13:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: chirala
Member: 1293395 Status: Offline Sonork: 100.1657302 Thanks Meter: 87 | xt1755 frp solution plz mtk 6737 chip moto xt1755 frp solution plz hear is the log Card found : S/N : A3B50E6B , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 255 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 257 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
05-12-2018, 13:50 | #3 (permalink) | |
No Life Poster Join Date: Feb 2011
Member: 1510086 Status: Offline Thanks Meter: 78 | Quote:
05-12-2018, 14:01 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @snak2;HAVE TIME TO TYPE MSG LIKE THIS BUT DONT HAVE TIME TO SEARCH AND READ SUCCESS REPORT THREAD FOR MOTO XT1755 ANYWAY IF YOU WANT TO SLOVE THE PROBLEM FOR YOUR PHONE THEN DOWNLOAD DA FILE FOR THIS PHONE FROM IOS SUPPORT AREA AND POST RESULT HERE GOOD LUCK |
05-13-2018, 08:18 | #5 (permalink) | |
05-13-2018, 11:00 | #7 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Use CM2MTK with DA provided here- http://forum.gsmhosting.com/vbb/12994641-post4.html Next time just use Search button. Br. Infinity Box Team. |
05-13-2018, 16:32 | #8 (permalink) |
Member: 1510086 Status: Offline Thanks Meter: 78 | [quotehello, use cm2mtk with da provided here- moto c xt1755 mt6737m|mt6737 locked with cert frp remove done next time just use search button. Br. Infinity box team.][/quote] not works sir where am wrong |
05-13-2018, 17:05 | #9 (permalink) | |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
hello rename your da to MTK_AllInOne_DA_SP.bin and put it in c:/infinitybox/cm2mtk/boot good luck | |
05-13-2018, 18:45 | #10 (permalink) | |
Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed | |
