syed tuqeer | 11-19-2016 15:01 | OPPO R1001 Stuck on logo after flash same :( Hello,
Flashed with working firmware , but same stuck on logo(no animation )
i tried hard reset, but show format/wipe failed Code:
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040501A1DA995139
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A1DA995139
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x2BFA537D8F5BF3AE9EAC7DC0AEA048E4
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : OPPO
ProdName : OPPO72_13076
ProdModel : R1001
Device : OPPO72_13076
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : R1001_11_A.13_141127_L
SECURITY :
IMEI_SW [1] : 8668930275530xx
IMEI_SW [2] : 8668930275530xx
BTMAC Addr : A81B5A3594EE
WiFi MAC : A81B5A3594EE
EXTRA :
LCD [0] : HT_WVGA_13033
LCD Res : 800x480
TOUCH [0] : gt9xx_13076
CAM [0] : s5k5cagx_yuv
CAM [1] : hi704_yuv
CAM [2] : s5k5catruely_yuv
MODEM : OPPO72_hspa_13076
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi
Done!
Elapsed: 00:00:18
Reconnect Power/Cable! Flashing logs.... Code:
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : oppo72_13076 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4028 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_oppo72_13076.bin
Preloader Sent , Init passed
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : RESERVE2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:22
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : RESERVE2
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:47
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:36 HW TEST Code:
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 88 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040501A1DA995139
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:49
Reconnect Power/Cable! is any way to repair it ? |
