03-31-2016, 11:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2015
Member: 2364508 Status: Offline Thanks Meter: 15 | Oppo r2001 problem NOW PRE LOADER ERASED. I ALREADY REPAIR IT VIA CM2 AND SUCCESS FLASH BUT SET WONT ALIVE. ANY HELP PLEASE. ======= Flash Files set for flashing : [ MCU ] : OPPO R2001.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A1FF085171 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A1FF085171 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 6EE4FE402E10C7565A6CFBED5DCBC045 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok! Brand : OPPO ProdName : OPPO82_13081 ProdModel : R2001 Device : R2001 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : R2001_11_A.01_141210_L ISPFF ID : 6582 , TARGET ID : 6582 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : OPPO R2001.bin Init Ok , Sending blocks ... Write done , 3728 blocks sent Done! Elapsed: 00:05:49 Reconnect Power/Cable! |
04-01-2016, 08:07 | #3 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | normally if have good backup is enough write with cm2, other way if still dead check in your device manager what status dont press any key in phone if show preloader ........ its mean have preloader or boot file. |
04-01-2016, 12:26 | #4 (permalink) | ||
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
didnt u take backup before formatting..? | ||
04-02-2016, 10:18 | #8 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | |
The Following User Says Thank You to LoveLess For This Useful Post: |
04-02-2016, 12:08 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | first try with this preloader |
The Following User Says Thank You to rehmani For This Useful Post: |
