Oppo R9s Plus Pattrn remove Error Card found : 00000000 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9F1C922F ID_BLOCK_L : 439405D02AE42F083959D06A50DCFC0E ID_BLOCK_L : 8BC52385DE99AF74F636297824860525 Use CM2 Internal Loader Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
Repeat procedure 1-2 times please and let me know result. Will fix if still no luck ( need hour or so ) |
Same error Boss, will wait on you |
Sent pm. Check it. And let me know result. |
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset UserLocks [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 9F1C922F ID_BLOCK_L : 439405D02AE42F083959D06A50DCFC0E ID_BLOCK_L : 8BC52385DE99AF74F636297824860525 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
hello friend.....throw your infinity box or dongle ,because it's useless without update......thankyou. |
@gsmkasba Did you ? For us still worth this box |
