04-30-2021, 10:18 | #1 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 254 | Oppo Reno 4 Z 5G CHP2065 LocalSLA fail Quote:
04-30-2021, 18:43 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | We didnt have yet samples on 6885/6873. Since we not copy other peoples work, we not added them at all yet. If you have it on hands and 10 minutes free time - we can add it. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
05-01-2021, 02:37 | #3 (permalink) | ||
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,057 | Quote:
Br, xerraco | ||
The Following User Says Thank You to xerraco For This Useful Post: |
05-01-2021, 10:53 | #4 (permalink) | |
Member: 25996 Status: Offline Thanks Meter: 254 | Quote:
I don't have that phone anymore. If only you'd reach out yesterday morning ;-) To be honest, i tried a couple tools, including Infinity, EFT, UFI and Octoplus - all failed. Pandora was able to read the phone correctly in bootrom mode and bypass, bypass the auth and do factory format, but even though log said it wiped frp partition, the phone was still asking for previous passcode or google account. I was able to bypass it since factory reset went fine. Long story short - chipset should be supported, and it's not patched yet, just need some testing. | |
05-05-2021, 15:05 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
That sensetive data not contain any phone/pc/user/etc.-unique data. | |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
05-07-2021, 21:20 | #8 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,105 | Easy to serve this mobile (mt6873) in cm2mt2 by using original exploit (python mtk exploit ) Mobile will be detected as plain (no sucured) in cm2mt2 Good luck |
The Following User Says Thank You to rebainoor For This Useful Post: |
06-09-2021, 12:48 | #9 (permalink) |
Freak Poster Join Date: Sep 2005 Location: still here Age: 40
Member: 185054 Status: Offline Thanks Meter: 22 | have phone in hand if needed. Code: Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6873 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Margaux TYPE : MODERN RAPHAEL BROM : MEID : DFB051A83C7E23E5D73A2D7F832E06C4 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : 5BD501FB034571F5098446FB4430BA1A6994B44CA22745E11A96F4B68DF40408 BROM : SLA : Local Auth BROM : Unsupported device : Report required! BROM : Report generated! INFO : Report sent! BROM : Local AUTH failed! Device not supported yet! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! |
06-09-2021, 17:00 | #10 (permalink) | |
We planned release MT2v225 today-tomorrow and can try with it. | |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
06-15-2021, 22:15 | #12 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | CPH2201 (Oppo Reno5 Pro 5G) Operation : Identify [ v2.24 ] Code: Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6885 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Petrus TYPE : MODERN RAPHAEL BROM : MEID : E25B34FF2EF13CFD348A0148A526E433 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 5320FDF5AAC28D2A79F3F5AA8CE1A9A4617BD5F203C8261D1D992C79D85CA36E BROM : SLA : Local Auth BROM : Unsupported device : Report required! BROM : Report generated! INFO : Report sent! BROM : Local AUTH failed! Device not supported yet! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! |
06-16-2021, 11:58 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | We finished MT6873 support, working, as expected. MT6885 under test. Will put in near hours to support, need finish some test now. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
