12-22-2009, 08:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | OT-600 : too many errors in log but Unlock Done :) Code: Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2003:A005 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0708135F rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, AC55EAAD address offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2AVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done ffs address assigned: 00C00000 startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.0708135F.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC].rpl warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.0708135F._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.0708135F.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC].rpl warning: rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.0708135F._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC_.rpl ==================== warning: unknown rom info structure: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC Unknown firmware detected (v.2.96, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000 error: can not recalculate address range, allowed offset is too small: 00006F54 error: can't calculate security area (sec info, part #1) security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 error: wrong erase first sector at 0x01000000 Finalization Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C707X_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38__system_log_0708135F_ADEA55AC_20091221-193417.B0X.bin Finished, time used: 165 sec Remove/Install battery now ! |
The Following User Says Thank You to nasirahmed For This Useful Post: |
12-22-2009, 21:40 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It was small bug with existing phone firmware type detected. It should be fixed here: http://www.infinity-box.com/download...e_v3.00_v3.rar |
1.27 too many errors | fabrtz | MSS Box II | 3 | 11-29-2009 17:22 |
Update imei tool !!! Please too many phones in negative band here in shouth America! | Anayami | Rocker Dongle (By Legija) | 4 | 04-25-2009 03:45 |
Too many doubts in Nokia models | mobilerocks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-24-2006 18:17 |
Picture Changer 3 + CX65 : too many errors... | PYCON | S-Gold Based Phones | 22 | 02-02-2005 20:26 |
