12-04-2009, 16:01 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
ot-363a flash need | boliargsm | Alcatel TCL Phones and New Models | 1 | 03-29-2010 20:10 |
21 Dec 2007: Alcatel Mandarina Duck, ELLE N3, LAVA, OT-C717, OT-C707, OT-C701, OT-... | InfinitySupport | Infinity-Box | 168 | 07-16-2009 10:00 |
12 Aug 2008: Alcatel-OT-C7xx, OT-C8xx, OT-V7xx, OT-S5xx imei repair in test etc. | InfinitySupport | Infinity-Box | 35 | 09-28-2008 20:40 |
UPDATE - 29 01 06 - TOTAL Alcatel VLE5 Commander ! OT-E15x, OT-E16x, OT-2xx NO SERVER | julvir | Redbox | 129 | 10-07-2006 21:33 |
