01-14-2018, 13:20 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | panasonic elugaa boot problem Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 037CD7C7 ID_BLOCK_L : C21A08B2D08D62E211A3456EBA53FA17 ID_BLOCK_L : ED81F80EAB73099C6F96E7B15EAFD324 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to SAJONDUTTA For This Useful Post: |
