05-02-2009, 07:34 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: italy bologna Age: 42
Member: 515942 Status: Offline Thanks Meter: 29 | panasonic x300 dead after unlock |
05-02-2009, 09:00 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Post here operation log for unlock process so we will be able to check it. Did you tried to restore original eeprom backup ? Did you tried to power-on phone without sim card ? |
05-02-2009, 11:17 | #3 (permalink) |
Member: 515942 Status: Offline Thanks Meter: 29 | here is eeperom writing and how i can restor orignail backup COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Flash write Skip: Firmware Skip: Map/Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Program Files\InfinityBox\QModule\DataEP15.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Eeprom area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 48 sec |
05-02-2009, 11:22 | #4 (permalink) |
Member: 515942 Status: Offline Thanks Meter: 29 | here is first unlock log COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Documents and Settings\XPPRESP3\Desktop\backup_eeprom_unlock-1_20090501-170356.04E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 error: error: flash write error: 047F8000:00002000 Write Done Finished Remove/Install battery now ! Time used: 23 sec COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Documents and Settings\XPPRESP3\Desktop\backup_eeprom_unlock-1_20090501-170435.04E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 17 sec |
05-04-2009, 20:44 | #10 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | Quote:
plz infinity team look here http://forum.gsmhosting.com/vbb/showthread.php?t=744864 | |
05-05-2009, 21:09 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
05-06-2009, 15:57 | #14 (permalink) | |
Member: 515942 Status: Offline Thanks Meter: 29 | Quote: after write this set is same condition here is log COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Flash write "smart write" enabled Skip: Firmware Skip: Map/Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Documents and Settings\XPPRESP3\Desktop\backup_eeprom_20090506-205453.04E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Eeprom area requested/selected: 02/02 error: error: Write Done Finished Remove/Install battery now ! Time used: 46 sec | |
05-06-2009, 19:36 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash phone with different repair files from support area: \flashfiles\Panasonic\X300\repair_eeprom Also try to flash phone with main + lp + map files the same version (flash all 3 files together). |
Nokia 2720 dead after unlock | unlocklleida | Cyclonebox | 3 | 03-31-2010 17:25 |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
Panasonic p341i dead after unlock by infinity | ashraf_bcs | Infinity-Box | 5 | 07-21-2009 07:46 |
Panasonic X300 Dead after unlock with PolarBox1 | said4 | Panasonic | 0 | 03-02-2007 23:55 |
