Old 09-03-2016, 09:38   #1 (permalink)
Member: 1004995
Thanks Meter: 230
Panosonic p55novo dead after flashing
Hi p55 novo dead after flashing.Here are the logs.
Operation : Fix Android Partitions [ v1.55 ]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 150100463732324D42000EE1DC552369
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
Firmware selected, but it NOT compatible!
Boot Error!
Operation Failed
Elapsed: 00:00:13
Reconnect Power/Cable!
Pls guide
Device has one gb ram
h/w vlot3
S/w v1037
Pls help
Old 09-03-2016, 13:41   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Where is flashing log? Which SW Ver you flashed?
Flash with v1037.
Br.
Infinity Box Support Team.
Old 09-03-2016, 14:12   #3 (permalink)
Member: 1004995
Thanks Meter: 230
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Flash with v1037.
Br.
Thx for response. Flashed with version 1037 with SP FLASH TOOL
SET has 1gb ram.
Earlier set was working slow.
Old 09-04-2016, 05:27   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Operation : Fix Android Partitions why this opration ??
show flashing log also read info log
Old 09-04-2016, 07:23   #5 (permalink)
Member: 1004995
Thanks Meter: 230
READ INFO
Card found : S/N : 5FF6169C , v0132
Chinese Miracle II [MTK module] v 1.54
Operation : Check / Read Info [ v1.54 ]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:11
FLASHING LOGS.
Scatter Load Ok , BaseBand : MT6592 , Project : s3569 , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.54 ]
======= Flash
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:12
PLS GUIDE
Old 09-04-2016, 07:28   #6 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
here 2 preloader try 1 by 1 init them and post log
Old 09-04-2016, 08:16   #7 (permalink)
Member: 1004995
Thanks Meter: 230
SAME PROBLEM.
LOGS.
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:23
User selected Preloader file : preloader_yulong89_wet_kk.bin
Operation : Init Preloader [ v1.54 ]
Supported HW by Preloader :
FlashID [0] CID : 1501004B3558564D42 , Name : K5XVMB , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX]
FlashID [2] CID : 1501004B3557564D42 , Name : K5WVMB , Vendor : 15 , [SAMSUNG]
FlashID [3] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:15
Ready to Flash!
User selected Preloader file : preloader_s3569.bin
FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 150100513858534142 , Name : Q8XSAB , Vendor : 15 , [SAMSUNG]
FlashID [2] CID : 150100523832314D42 , Name : R821MB , Vendor : 15 , [SAMSUNG]
FlashID [3] CID : 150100513732534D42 , Name : Q72SMB , Vendor : 15 , [SAMSUNG]
FlashID [4] CID : 150100513832534D42 , Name : Q82SMB , Vendor : 15 , [SAMSUNG]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:15
======= Flash
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:08
Old 09-04-2016, 08:54   #8 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
EMICFG_NOT_FOUND
which boot key u hold ?
Old 09-04-2016, 10:33   #9 (permalink)
Member: 1004995
Thanks Meter: 230
No boot key is held
Sent from my F1f using Tapatalk
Old 09-04-2016, 14:29   #10 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
JUST UNSELECT FW!!!
Sw clearly told about this.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-04-2016, 15:24   #11 (permalink)
Member: 1004995
Thanks Meter: 230
Thx for ur kind reply. Pls explain a little more. Thx
Old 09-04-2016, 15:28   #12 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
open cm2
dont select any flash file
now init preloader from upper post 1 by 1 and check
Old 09-04-2016, 16:03   #13 (permalink)
Member: 1004995
Thanks Meter: 230
open cm2
Thx for your kind support.I am performing this operation without selecting any flash file.
LOGS.
Card found : S/N :
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:26
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:21
Old 09-04-2016, 16:09   #14 (permalink)
JayDi's Avatar
Member: 462970
This preloaders are NOT compatible with that phone at all.
Inside phone Samsung F722MB eMMC
Old 09-04-2016, 16:28   #15 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
oh yes tomorrow i give read preloader
wait plz
Page generated in 0.27059 seconds with 9 queries
