Old 09-08-2006, 02:39   #1 (permalink)
Member: 124680
Thanks Meter: 2
Solution to unlock C168
COM1 selected
Device: C168
Checking data, wait...
Action: Unlock
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1120-000
HW ver: TCT-5-
Check Flash Done
Check Parameters...
file saved: Backup_unlock_2006-9-7_23-52-29.69F.bin
Err: unknown or damaged device. read flash and send to support
Check Parameters Fail
Finished
Remove/Install battery now !
Time used: 22 sec
Make "SP-Unlock" operation now !
This is the message I recieved when unlocking Motorola C168 phone and the phone can't come on now so please help me attached to this is the flash file I read from the dead phone
Old 09-08-2006, 06:50   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by Kwame_11 View Post
COM1 selected
Device: C168
Action: Unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1120-000
HW ver: TCT-5-
Check Flash Done
Check Parameters...
Finished
Time used: 22 sec
Hi,
Use latst Moto02 module v1.19 from support area to unlock this phone (firmware 1.120 supported).
C168 can't be killed during unlock, especially when software just check unlock possibility and terminate operation before make any changes in phone memory (it's your case), so just check battery (charge it) and try to press and hold phone power buttom for some time and for sure your phone can power-on.
Old 10-10-2006, 19:00   #3 (permalink)
vandal's Avatar
Member: 45656
Thanks Meter: 31
what cable can i use to unlock c168 the cable i use for c139 can connect with c168 any ideal mates
Old 10-10-2006, 22:02   #4 (permalink)
Member: 130995
c168 cable is absolutely the same as c139 cable.
Old 10-11-2006, 00:27   #5 (permalink)
nomangsm's Avatar
Member: 121662
Thanks Meter: 39
we used usb cable or only RJ45......
Old 10-11-2006, 05:21   #6 (permalink)
H.Y.K's Avatar
Member: 169753
Thanks Meter: 3
You can use com cable.(same T191)
Old 10-11-2006, 08:08   #7 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 03335548581
Thanks Meter: 1,607
wat is the name of cable is tha gx 60 or 50 (3 pin or 2 pin ) cablw will b use plz guide properly
Old 10-11-2006, 08:38   #8 (permalink)
minhtrimobile's Avatar
Member: 87020
Thanks Meter: 9
gx60 is exacterly!good luck!
Old 05-16-2007, 22:26   #9 (permalink)
Member: 504975
hello please guide me that who can sp-unblocking c168 .any software ,cable
r sported this model.
Old 05-16-2007, 22:31   #10 (permalink)
Member: 504975
my id is [email protected]
[email protected]
pakistan
Old 05-16-2007, 22:51   #11 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
all your questions is answered in our Shell module.
run it, pick model C168- you will see which cable to use
and also needed program will open automaticly.
all what you need- to pick right com port to work with.
then go to service tab and push "unlock"
Old 05-23-2007, 11:43   #12 (permalink)
Member: 269766
Thanks Meter: 12
Which soft do i use to unlock the c168?
Old 05-23-2007, 12:59   #13 (permalink)
Member: 130995
Hello,
Just use latest Infinity-Box "Shell", select model C168 and you will be able to unlock phone.
any free solutio, to unlock c168? jawad8305 Motorola ODM 2 04-15-2008 10:42
how to unlock c168 qayyoom1 Smart-Clip 2 04-15-2007 12:46
Failed to unlock C168 with SmartMoto 2.19 ? ales6orah Smart-Clip 12 02-24-2007 21:30
is it possible to unlock c168 and w220 ? harish35200 Smart-Clip 3 02-02-2007 07:11
How to unlock Z150 Movistar - Spain? There are any solution to unlock this new model? Grupo MovilFree QUALCOMM Models (3G) 7 09-22-2006 16:35
Page generated in 0.38144 seconds with 9 queries
