10-27-2011, 20:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dominican Republic Age: 40
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 70 | Pcd clx100pr dead after reset ==== c:\InfinityBox\MModule\MModule.exe [10/27/2011 2:32:37 PM] ==== Infinity-Box - Multibrand Unlock & Repair Tools support forum: Infinity-Box - GSM-Forum Loading data, wait... [Infinity Box] MModule v4.05 smart-card: connected S/N: 750F:0116 Wait... trying to select model: /CLX100PR model selected via command line: PCD-CLX100PR Device: PCD-CLX100PR Initialization done COM9 ready ==== [10/27/2011 2:32:52 PM] ==== COM9 [VCP2] selected module v4.05 Action: read unlock codes unlock method: read codes Model: PCD-CLX100PR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: C2097_2.2_0x1211F_CLR_PR_NUMO Version: CELLONSZ35_09A_HW 83 byte(s) read imei: connection Ok 189 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 4 byte(s) read error: source data size is less than expected 177 byte(s) read reading data... 4 byte(s) read warning: unknown lock version: 589C41F9 error: operation failed ! Finished, time used: 25 sec Remove/Install battery now ! Device: PCD-CLX100PR ==== [10/27/2011 2:34:00 PM] ==== COM9 [VCP2] selected module v4.05 Action: read unlock codes unlock method: read codes Model: PCD-CLX100PR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: C2097_2.2_0x1211F_CLR_PR_NUMO Version: CELLONSZ35_09A_HW 83 byte(s) read imei: connection Ok 189 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 4 byte(s) read error: source data size is less than expected 177 byte(s) read reading data... 4 byte(s) read warning: unknown lock version: 589C41F9 error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [10/27/2011 2:34:24 PM] ==== COM9 [VCP2] selected module v4.05 Action: reset settings ("format ffs") Model: PCD-CLX100PR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: C2097_2.2_0x1211F_CLR_PR_NUMO Version: CELLONSZ35_09A_HW 83 byte(s) read imei: connection Ok building list... done items to clear: 247 warning: wrong packet cs warning: wrong packet cs items cleared: 246 of 247 building list... done items remains: 0 Finished, time used: 46 sec Remove/Install battery now ! smart-card: disconnected ==== c:\InfinityBox\MModule\MModule.exe [10/27/2011 2:43:32 PM] ==== Infinity-Box - Multibrand Unlock & Repair Tools BB5 Easy Service Tool [BEST] - Infinity-CDMA Tool PinFinder Adapter Language Pack Editor Dongle Content Extractor Dongle sales department: [email protected] support forum: Infinity-Box - GSM-Forum Loading data, wait... [Infinity Box] MModule v4.05 smart-card: connected S/N: 750F:0116 Wait... trying to select model: /CLX100PR model selected via command line: PCD-CLX100PR Device: PCD-CLX100PR Initialization done COM9 ready Loading file v.05... error: buffer error ! Loading failed, probably damaged data file smart-card: disconnected smart-card: connected Loading file v.05... PCD-CLX100PR_CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.C20 97_2_2_0X1211F_CLR_PR_NUMO_2010-11-01_En_Es.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.C2097_2_2_0X 1211F_CLR_PR_NUMO.BIN project-id: C2097_2.2_0x1211F_CLR_PR_NUMO, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-11-01 17-50 hw1: CELLONSZ35_09A_HW hw2: 09A_1.22_CELLONSZ35_09A ==== [10/27/2011 2:47:13 PM] ==== COM9 [VCP3] selected module v4.05 Device: PCD-CLX100PR Checking data, wait... Action: write flash NAND write: Firmware PCD-CLX100PR_CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.C20 97_2_2_0X1211F_CLR_PR_NUMO_2010-11-01_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_C2097_2_2_0 X1211F_CLR_PR_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0026]: 0020:00A100000015 [ST] ST01GR3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: C2097_2.2_0x1211F_CLR_PR_NUMO detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_C2097_2_2_0 X1211F_CLR_PR_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.C2097_2_2_0X 1211F_CLR_PR_NUMO.BIN project-id: C2097_2.2_0x1211F_CLR_PR_NUMO, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_C2097_2_2_0 X1211F_CLR_PR_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 8 min 38 sec Remove/Install battery now ! Last edited by InfinityHelp; 06-27-2020 at 10:07. Reason: legacy links removed |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
