>>> Permanently Blocked Alcatel E227x Unlocked Ok with infinity <<< Infinity Box unlocked permanently blocked Alcatel E227x (Orange UK) w/o any problems... However, Code read was also successfully done by Easy Unlocker, but could not enter code as the phone was permentaly blocked.. This phone was unlocked directly by Infinity.. Thanks to this team >>> COM4 [VCP1] selected module v1.30 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090202-204912.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 65 sec Remove/Install battery now ! |
thanks br good work keep it up........... |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
COM9 [VCP0] selected module v1.33 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090701-155548.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 83 sec Remove/Install battery now ! work fine i use the cable from the microbox alt e256 work fine:D |
unlock alcatel e227x with succes unlock alcatel e227x with succes by infinity-box |
thanks for info brothers |
Thanks Brother for info Good Work Keep it UP. |
why infinity didn`t support more alcatels? like e256 |
