05-04-2009, 10:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | philips 192....done action taken.......resett settings RESULT=working perfect.here r logs COM5 [Serial2] selected module v1.61 Device: Philips-192 Checking data, wait... Action: reset Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 58 P192_I7880F_0714B01_V20CNx Feb 2 2008 04.13.00 18.26.13 08. Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20090504-141604.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20090504-141606.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20090504-141612.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 27 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to neetika99 For This Useful Post: |
05-05-2009, 21:24 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
09-14-2009, 11:20 | #3 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | Quote:
The Following User Says Thank You to anis_rainbow For This Useful Post: |
09-15-2009, 00:01 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Philips-192 user code reset Help ple. | nishue | Infinity-Box | 2 | 02-15-2010 19:22 |
philips 192 simlock error ??? | turkcellgsm | Infinity-Box | 2 | 11-08-2008 14:53 |
Philips 192 tested | nafanya | Infinity-Box | 1 | 06-20-2008 09:28 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 22:02 |
hi I need philips 192 phone code reset | ardagul | Philips | 3 | 03-30-2008 11:57 |
