05-24-2018, 19:05 | #1 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1958357 Status: Offline Thanks Meter: 42 | Phone dead after writing its Cm2 Backup Start at : [5/24/2018 / 5:20:36 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3331453BB80D42573FFDDC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DB83BDCFD4457 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x331D05F0F6E7EF9CC9750C30CFD892F0 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Infinix ProdName : X601-LTE-C1 ProdModel : Infinix NOTE 3 Pro Device : X601-LTE AndroidVer: 7.0 MTKxCPU : MT6735 MTKxPRJ : X601-H537C-N-170520V41 [Read Ok] : preloader_rlk6753_65_n.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6753 / V1.1.2 / rlk6753_65_n / EMMC Android Info saved HWConfig Info saved FW Size : 3653 MiB Scatter saved to : C:\MT6735__Infinix__Infinix_NOTE_3_Pro__X601-LTE__7.0__X601-H537C-N-170520V41\ |
05-25-2018, 14:28 | #5 (permalink) |
Member: 1958357 Status: Offline Thanks Meter: 42 | Mr Jaydi, i read backup from this same phone, after writing it back, the phone became dead. which means cm2 did not back up the firmware correctly, i was able to fix the phone by downloading a factory rom. so i am afraid of using anyother Cm2 backup of MT6753 cpu. |
05-25-2018, 14:33 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
its good if you provide flashing log any error in flashing ? after flash log also useful for good sugestion | |
05-25-2018, 14:52 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Remove all CM2 backups and use other tools! Or just provide, finally, all logs. | |
05-25-2018, 19:30 | #8 (permalink) |
Member: 1958357 Status: Offline Thanks Meter: 42 | Mr JayDi.... No need to be rude I just need clarifications No flashing Log. Because I flashed phone with SP FLASH TOOLS. AND THERE WAS NO ERROR... ARE YOU TELLING ME THAT ONLY CM2 CAN WRITE THAT FILE TO PHONE CORRECTLY? THAT ALL I WANT TO KNOW SO THAT I DONT MAKE THE SAME MISTAKE AGAIN. |
05-26-2018, 15:44 | #10 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
