04-12-2008, 11:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | Phones are not powering on pinfinder adaptor I just bought a new pinfinder but i cant b able to power on the phones on this pinfinder!.....I did modifcation in my infinty box as described in manual but still same!.....I only getting 4volts on the end of the cable even after modifcation.....THis pinfinder is also not b able to find piinouts on most phones as i m using battery....and during proccess the phone get power on.......and also getting 19200 fixed in the log lots of times!....i only able to fine only one phones pinouts but then cant b able to format it on the chinese miracale software......When i connect the phone and press power button getting the error that "boot step 1 failed"......I m using battery for the whole process as i cant b able to powe the phone on adaptor or infinty box.....So plz help me....I m waiting.......May b my question is so silly but i already read the manual carefully but not find any thing to solve it! |
04-12-2008, 12:07 | #3 (permalink) |
Freak Poster Join Date: Jan 2006 Location: SURESH ELECTRONICS, INDIA Age: 49
Member: 216081 Status: Offline Sonork: 100.1614205 Thanks Meter: 55 | In my case first I have 4.15v on battery terminals, I used to work with some phones(not all) pin finding, and also they got powered on with 4.15v. I then made a jumper according to the pin finder manual, now its 4.85v. Now I am able to do with all phones. I think you have to change the usb cable which you are using to connect infinity, and then measure voltage on the usb port, or change the usb port to backside of pc, which directly connects to the port without any wire. As we all know usb gets definitely 5v. Best of luck! |
04-12-2008, 12:18 | #4 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | Quote:
For finder process, its didnt use battery, use cable(red connect to + and black connect to -) from infinity finder, after that press power on finder software, and power on the phone, see if the phone can power on or not? PS. some chinnese phone got internat batt like CECT C2000(phone can poweron even didnt attach batt) | |
04-12-2008, 12:28 | #5 (permalink) | |
As per your explanation I can see that you did not read manual and did not followed pinout detection procedure ! You must use power wires from PinFineder Adapter but NOT from battery ! Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf And please, read it and follow instruction ! We have spend a lot of time trying prepare this manual ! If you will have any problems just explain what is the problem exactly but DON'T WRITE THAT YOU CAN NOT FIND PINOUT WITH BATTERY CONNECTED ! | |
i connect the DC supply but phone does not power on | kaholukkk | UID - Box | 2 | 10-06-2007 15:38 |
MyX-4 affter flash the phone can not power on | Amnarj | SwS_SaG_BoX | 8 | 03-18-2006 21:29 |
c60 phone is not power on | mas comm | Siemens Hardware Repair Area | 0 | 10-28-2004 11:30 |
A55 phone is not powered on when try unlocking!!!!!!!!!!!! | wabou | E-Gold Based Phones | 5 | 08-15-2004 17:22 |
