Old 04-02-2008, 16:12   #1 (permalink)
Member: 411831
Thanks Meter: 215
Post need help to flash cect u8810 (tv mobile)
hi all ,
cect u8810 (tv mobile) when i press power on it start 1%....to 100% and show
welcome and resart and restart.
i formatted by infinity but same.
logs............................
COM7 [VCP0] selected
Action: reset settings
Model: Autodetect 6228 NAND
Checking data, wait...
19200 autodetect
Initializing[6228:8A02:8A02]...
CPU: MT6228
high speed boot enabled
chip: 0031:0000:0101
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 97 sec
Remove/Install battery now !
19200 autodetect
CPU: MT6228
Connecting, wait...
Finished, time used: 100 sec
so i flash it by this version"BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_ 7670_HYN_HY128_V2_1__Cect-N528_128m_En_Cn.B4M"
logs...............
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.35
S/N: 0D90:010E
Wait...
Device: Autodetect 6205-6227 NOR
Done
Device: Autodetect 6228 NAND
Loading file v.02...
BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M.bin loaded
identification#1 protocol ver: 04
ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN
ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424
You have loaded file with security features enabled.
detecting languages...
Languages: En Cn
Action: write NAND flash
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
ffs offset/size: 02000000/06000000
id-page1 Ok
nfi area detection finished: Ok
Boot...
19200 fixed
Connecting, wait...
CPU: MT6228
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
loader: 3.1.02
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:00F10080001D [08400000]
NOR chip is not installed
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
reading structure area...
detecting structure...
warning: probably flash chip completely erased, no bootloader found
nfi area detection finished: failed
error: can't detect nand chip parameters, default values assigned
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._BXWY 28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN_HY1 28_V2_1.BIN_DBBB7B34_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_ 432_7670_HYN_HY128_V2_1.BIN_DBBB7B34_.rpl
warning: unknown identification#1 structure: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34
error: Unknown firmware, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "backup_system_log_..." file to support: [email protected]
- make "Read full flash" operation
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
You can flash phone now but can't finalize it.
In most cases phone can NOT power-on normally.
Do you want to write flash anyway ?
Initialize bootcode Done
Check firmware integrity...
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
write core area 1 of 3...
write core area 2 of 3...
error: code: A500000BF1
error: code: 5AA51C00
error: code:
error: block/offset: 000000A2/000A2000
error: can't write nand core
Backup required data Fail
Finished, time used: 557 sec
but same...........
i don't know which version should use????
now phone is only boot(black screen,not white)until i press power button.
PLEASE HELP ME OUT.
ALOT OF THANKS
Old 04-02-2008, 16:59   #2 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
hello pro
1- set boot packet size to 2
2-port com speed to slowed test and post result
Old 04-02-2008, 20:24   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@msantar
1. charge battery completely and try again
2. try to use another flash file
3. try to reball (rehot) flash chip
Old 04-03-2008, 19:14   #4 (permalink)
Member: 411831
Thanks Meter: 215
Originally Posted by InfinitySupport View Post
@msantar
i try as to you sir, but same...................
need help,
need help to flash e50 adead nokia e50 ?help pls abdelnasr56 Nokia Base Band 5 ( BB-5 ) 1 07-02-2008 14:06
NEED HELP to flash 6235 problem are blink auto shutdown stop at flashing content Pac S E N O P A T I Nokia CDMA 2 01-01-2008 07:32
NEED HELP to flash 6235 problem are blink auto shutdown stop at flashing content Pac S E N O P A T I Nokia CDMA 0 11-22-2007 14:21
need help to flash my w550i!!! please help! rockett2k5 Sony Ericsson 1 06-27-2006 09:13
Need help to flash the T39mc subaru Old Ericsson Phones & Sony Phones 0 05-24-2003 08:35
Page generated in 0.18054 seconds with 9 queries
