Old 09-20-2008, 21:35   #1 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
vk530 unknown flash chip
its no power vk530 when i read eeprom or flash = after read unknown flash ship. what does it mean please
COM57 selected
Device: VK530
Checking data, wait...
Action: Read Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
file saved: backup_eeprom-02_20080921-222313.23F.bin
Err: unknown flash chip: 04AF:EA01:04AE:EA01
Finished, time used: 52 sec
Remove/Install battery now !
Old 09-20-2008, 21:45   #2 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
i wanted to write ffs this is result; is the flash ic damaged ?
COM57 selected
Device: VK530
Action: Flash write
Smart Write active
Skip: Firmware
Write: FFS/File system
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Check Space Fail
Finished, time used: 19 sec
Old 09-21-2008, 09:02   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It looks like it's hardware problem, probably flash IC is damaged or bad soldered (due to even flash chip type can not be detected well).
Also it may be water inside.
Old 09-21-2008, 12:55   #4 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
thank you infinity for quic reply
Page generated in 0.15141 seconds with 9 queries
