02-04-2009, 17:20 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 771601 Status: Offline Thanks Meter: 10 | pinfinder not detucted rx tx whats problem?? (or more) and repeat operation (parameter "Finder activation tries") software version: 1.16 cable type: 1x8 (L8A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 27 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Cable: 1x8 (L8A) Power On ! software version: 1.16 cable type: 1x8 (L8A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM5... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 27 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") plz help team & useres why this problem i m new & whaat is set parameter to value 20 all phones & working phones plz help |
02-04-2009, 20:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,535 | hello! first of all you must make sure that you have mt62xx MCU phone. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx second: connect phone to box power and try to power it ON. if it does not power On- you must modify main infinity box (remove diode) and might be need to add capacitor to pinfinder output. both procedures are available in pinfinder user manual. third: you must press power button and hold it all the time while program search pinout. please check if all steps are correct in your case |
06-07-2010, 19:29 | #3 (permalink) | |
Insane Poster Join Date: May 2007 Location: sri lanka,kurunegala
Member: 518978 Status: Offline Thanks Meter: 9 | sir i have same problem ... I also remove dide & make jumper.., 1000 mf 6.3v cap.but same problem.. Quote:
06-07-2010, 20:39 | #5 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 42
Member: 1203577 Status: Offline Thanks Meter: 24 | yes really it's very hard now the work with pinfinder i dont know why not infinity team slove this problem he cant detected any mobile and i have trust in infinity team if i can advandced he can fixed all the problem for us let wait what he can do for us infinity team you are great and i hope you give great work for pinfinder |
06-08-2010, 18:27 | #6 (permalink) | |
Member: 518978 Status: Offline Thanks Meter: 9 | Quote:
06-08-2010, 19:30 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,535 | Quote:
lets start from beggining. when you connect power wires to phone, run pinfinder software, can you power On phone from pinfinder power? for this you must select cable type and press "Power On" button in software | |
06-08-2010, 20:38 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Same Problem IPF can't detect any Phone Hello @Supporters i have the same problem. My Pin Finder doesn't detect any phone, with an Alcatel 303 (for testing) on hand and the right procedure (as i read in FAQ) i modified my Infinity Box (using the specified Jumper), with a multimeter i check wires have 4.9V, but phone is never detected eather if i set manually the correct pinout no luck. What more can i do to use it please? Thanks In Advance! Last edited by John(LMT); 06-08-2010 at 20:44. |
06-09-2010, 12:51 | #10 (permalink) |
Member: 1203577 Status: Offline Thanks Meter: 24 | yes sir i agree with you i hope infinity team do something for us because it's the time for he tested her pinfinder he must update her fw for detected the new mobile plz infinity team with usbfinder spider man i can detected anymobile ut with pinfinder i must solder and i waist time for nothing ....you are great team do something for your pinfinder software |
06-09-2010, 18:18 | #11 (permalink) | |
there is also small chance that pinfinder itself is defective. if you sure that you doing all correctly- i think best way is to send it to reseller for testing | |
06-09-2010, 18:52 | #12 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | Solution Needed.- Quote:
Thanks in advance.- | |
06-09-2010, 23:12 | #14 (permalink) |
Member: 507536 Status: Offline Thanks Meter: 75 | Hey bro i don't think it is a Software Bug, mine is the Infinity Pin Finder hardware, because SW runs normally, so i would like to know which components to check to be sure hardware has malfunction.- |
BESTEL 5000+ I can not find rx tx on the socket on the motherboard or the phone | Master911 | Chinese Models & Cloned Phones | 0 | 12-02-2009 16:37 |
ve pro not find rx tx | b.t.basheer | VE-PRO BOX | 1 | 02-23-2009 03:24 |
super doctor Mtk cable Rx Tx define problem | genius2005 | Chinese Models & Cloned Phones | 1 | 01-22-2009 14:08 |
help: pinfinder cannot detect RX TX | MARK26 | Infinity-Box | 5 | 10-02-2008 02:42 |
MC-TOOL Not found RX TX | rashel.com | MC-Tool | 0 | 04-06-2008 13:46 |
