Pinfinder pinout is the 2nd cpu, but "chinese Miracle" not write imei 1 Attachment(s) I'm with a unit (AOTE 660) that pinfinder found 4 different pinning (2 to reverse not active and 2 with reverse actived) but the software chinese miracle so recognizes the phone in two of those pinning 4. I'm trying to change the imei the second cpu, but when writing the imei, so modify the imei of cpu 1, independent of pinning that I set in pinfinder. I believe that pinfinder recognizes the pinning of the second cpu, but the chinese miracle can not access it. It is this? I ask to help me. |
If you need to repair imei for 2nd CPU you must use pinout for MT6205. Did you tried to use different imei repair methods ? |
I did just that, but the changes the imei of " SIM 1 ". The sim 2 , not change. |
If you need to repair imei for 2nd CPU you must use pinout for MT6205. Did you tried to use different imei repair methods ? What pinout you have used for 2nd CPU ? Show here operation log |
In mode 1 Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! Operation failed ! Finished, time used: 80 sec Power off phone now ! In mode 2 COM3 [VCP0] selected Action: imei imei write method: mode-2 new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 96 sec Remove/Install battery now ! In mode 3 COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 350448011234561 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 57 sec Remove/Install battery now ! If I make with the MT6226 has no problem. But so changes the imei of SIM 1 |
hello! for me looks like you releasing power button too fast. hold in pushed until program detect flash IC |
