pinout for a960 shaking phone 1 Attachment(s) here the pic of set plz give me solution |
plz give me the pinout for this set 18pin conector i m not found the rx tx beacause set is dead Thanks in advance |
sorry model is mpeg4 a950 |
hello! looks like very rare model A960 with 18pin connector. are you sure it is MT processor based? Also have you opened phone and looked for marked test points on PCB? |
i have two model one is a950 or sec is a960 both are dead condition and i m also check pcb i m cantt find marked pinout thanks for ur replay sir |
hello! are you sure they are MT processor based? |
yes sir i m sure beacause i m open the set and see the ic |
hello! in this case as long as nobody helping with pinout i would advice you to find it by yourself. just measure voltage on all pins and then reffer to this tutorial: http:///vbb/attach...7&d=1187384324 this is easy 10min job |
thanks u r always ready for ur customer help |
sir i m find the pinout but when i m format the set software says new finware detected after ok show this error Flash erease error:00EC0000.Retry? pinout is =1 !!!!!!!!!!!!!!!!!!! 18 18pin conector 8pin= gnd 13pin =rx 14pin-tx sir plz give me the solution thanks inadvance |
when forma t stra has says cant detect eeprom /FFs area do u want to use standerd ffs adress :00E00000 |
phone stop on stratup screen is mt 6226 base phone |
hello! first of all make full backup of phone firmware for emergecy case. after this make format FFS in safe mode later, if will not help- make FFS format in complete mode, using this "standart address" |
sorry sir i m asking a ouestion i m where from select" standart address" option sir i m try to format the set safe or complete but set always accpett only complete format and alwys give this message flash erease error 00EC0000 sir if possible plz help me for standerd addrees with picture Thanks in advance |
hello! please post here full formating log to see what exactly going wrong |
