pinouts for sands A203 hi , anu bodY could pls uplaod the correct pinouts for sands A203 :confused: |
wow. infinity have his Chinese Miracle section.. |
Here is the pinout for Hintel 3, 7, 19 - GND 20 - Vcc 9 - RX 13 - TX |
You can use Infinity-Box two "format" options: "complete" and "safe" and bothoptions should be used with the same pinout. Only "Imei" option can be used with other pinout (ordinary USB data/modem cable and USB drivers). |
so dificult to find the right pinout, i think format will solve my problem, the phone hang and restart with sim card where are the chinese? it's ur phone! :) |
Its wrong a203 pinout no it is not working . tx rx is not correct |
@a203 keypad up left 1 to .... 3 and 4 are tx and rx @a203 keypad up left 1 to .... 3 and 4 are tx and rx its 100% woring if not work swap rx and tx ok best of luck best regards cellworld:D:D:D:D |
bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
Would be great if you could add this option to your software too |
