Old 12-26-2009, 05:24   #1 (permalink)
Member: 701891
Thanks Meter: 3
pinouts skysen st1
no cable 2x7 (L14D)
5: box Rx/phone Tx (RJ45 pin-3)
1: box Tx/phone Rx (RJ45 pin-2)
it doesn't work like she/he goes connected correctly this telephone, pinouts please.
Old 12-26-2009, 07:44   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
hello,
its chinese made mobile , if you have pinfinder please try to find pinout with pinfinder . if you did not found any pin with infinity pinfinder then open mobile check rx tx on board and next time always post chinese mobile problems/discussions in chinese miracle section.
There are a lot of different "Chinese" phones with the same name but absolutely different hardware exist on market.
Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware, so it's impossible to
give any advice about phone pinout only by phone name.
So we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http://forum.gsmhosting.com/vbb/show...36&postcount=7
4. if not helps, please read: http://forum.gsmhosting.com/vbb/showthread.php?t=433447
Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en
Faisal_Computer
Old 12-27-2009, 13:34   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by jose rosales View Post
no cable 2x7 (L14D)
Hello,
Did you tried to use PinFinder or you have tried to use your own cable ?
If you have tried to use your own cable you need to connect GND pin also. You can connect GND wire to phone "-" battery.
Old 12-27-2009, 21:49   #4 (permalink)
Member: 701891
Thanks Meter: 3
COM7 [VCP0] selected
modulo v3.00
Action: read unlock codes
Metodo unlock: read codes
Modelo: Skyzen-ST1
Checkeando datos, espere...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
19200 autodetect
error: boot phase #2/1 failed
Can not initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method
error: La operación falló !
Finalizado, tiempo usado: 10 sec
Quite/coloque la bateria ahora !
Old 12-27-2009, 21:50   #5 (permalink)
Member: 701891
Thanks Meter: 3
configuration: pinout_380
Cable name: SkyZen-ST1
cable 2x7 (L14D)
Old 12-28-2009, 10:17   #6 (permalink)
Member: 130995
@jose rosales
1. Did you tried to use PinFinder or you have tried to use your own cable ?
2. If you have tried to use your own cable you need to connect GND pin also. You can connect GND wire to phone "-" battery.
Please, give me an answer to my question and let me know about your results with GND pin.
i want E66 UFC pinout abdurrahimsagar Nokia Hardware & Hardware Repair 2 05-27-2010 20:37
Pinouts for Wi-Fi Mobile C5000 Stoyan Infinity-Box 3 04-01-2010 06:06
CD player pinout 1J0 035 119c attilaa0 CAR Electronics 4 03-30-2010 07:16
need pinout sigmatel fxd 3600 bassemzini Infinity-Box 0 03-29-2010 19:22
S100/105.Pinouts.I don't quite understand pinout from S105 scheme. DoctorV Trident/AGERE Platform 9 04-03-2003 07:14
Page generated in 0.20370 seconds with 9 queries
