Old 12-16-2017, 16:44   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Micromax x751 usercode problem
USER CODE RESET FAILED I HAD TRIED
PLS HELP ME TO DO RESET
Old 12-16-2017, 17:02   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Did u Try on SCR module wht error do u get plz post logs for better help
Old 12-19-2017, 14:20   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Originally Posted by princesaddam View Post
Hello,
Card found: S/N : 85B43663 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot didn't start! Check model selection!
Boot Error!
Break
Reconnect Power/Cable!
Old 12-19-2017, 14:41   #4 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
3. Insert battery
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Error!
Break
Hello,
Read again and again and again I said SCR module not spd try in SCR module
Sent from my S_plus using Tapatalk
Old 12-19-2017, 15:08   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Hello,
where is SCR module in spd tool?
i cant find any where in soft
Old 12-19-2017, 15:21   #6 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Hello,
thanks bro problem solved
Card found : 85B43663 , v0136
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.01
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR
SPRD mode : SC6531 : REV : 0000 : NOR
Operation : Read UserCode [ v1.01 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
ERROR : FDL NOT started!
Error : Loader send failed!
Wrong model selected! Select correct one!
SPRD mode : SC6531 : REV : E000 : NOR
Operation : Identify [ v1.01 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] : 911583752345549
IMEI[2] : 911583752345556
Done!
Elapsed: 00:00:12
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
STATE : ACTIVE : CODE : 5252
Done!
Elapsed: 00:00:10
The Following User Says Thank You to umarmsn For This Useful Post:
Page generated in 0.17127 seconds with 8 queries
