Old 12-12-2017, 13:08   #1 (permalink)
Member: 2501288
Thanks Meter: 328
Unhappy SCR i9500 SC6531 dead after format
dead after format pleas any one has this firmware upload here
Operation : Format FileSystem [ v1.01 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531 Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [MICRON] : N25W128 : 0x01000000 [ 16MiB ]
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:49
Reconnect Power/Cable!
Old 12-12-2017, 17:37   #2 (permalink)
Member: 2501288
Thanks Meter: 328
pleas firmware to revive this crap
Old 12-12-2017, 20:20   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Read and upload dump from it. From current state.
Old 12-12-2017, 20:34   #4 (permalink)
Member: 2501288
Thanks Meter: 328
https://www.4shared.com/file/58HtzHKXei/FLASH_DUMP.html
Old 12-12-2017, 20:37   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
My infinity credit Mr Jaydi for Nokia firmware
Old 12-12-2017, 20:42   #6 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by Steve-1 View Post
Got it. Will try check where can be a problem and re-build or fix file. Near 8-20 hours, depend on free time.
The Following 8 Users Say Thank You to JayDi For This Useful Post:
Old 12-13-2017, 20:37   #7 (permalink)
Member: 2501288
Thanks Meter: 328
i m still waiting sir .....
Old 12-13-2017, 22:45   #8 (permalink)
JayDi's Avatar
Member: 462970
I had checked dump and MCU code completely Okay - that is most important. Seems as it was semi-dead already, need just find good NVRAM golden copy. Trying find according MCU.
Old 12-14-2017, 00:20   #9 (permalink)
Member: 2501288
Thanks Meter: 328
The phone was alive just with phone code, i do format fs after thats not power on!!!
Old 12-16-2017, 18:34   #10 (permalink)
Member: 2501288
Thanks Meter: 328
any one pleas has this nvram upload here
Old 12-16-2017, 18:47   #11 (permalink)
Member: 2501288
Thanks Meter: 328
problem solved, phone revived by this firmware here
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR
SPRD mode : SC6531 : REV : 0000 : NOR
BINARY : GT-I9500-EN-full-by-Aladdin-abdu.bin
FLSIZE : 0x01000000
Load Ok!
Operation : Write Flash [ v1.01 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Done!
Elapsed: 00:05:09
@ JayDi pleas fix this problem
reagrds
Old 12-16-2017, 19:27   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
in addition to this, Mr Jaydi you cant read codes from this CS0_MEM : SPI : [MICRON] : N25W128 :
Sw just hang after boot phone,thats why this user decided to Format device,then DEAD !!.
I have set in hands with password.
Old 12-16-2017, 20:29   #13 (permalink)
JayDi's Avatar
Member: 462970
Is it your id, or you just hijack other thread? Dont mix, if it different phones.
Since you have dump - repeat format again and check result after.
If you have locked device , which code not read - read dump and send for checking. Dont waste time for nothing.
Old 12-17-2017, 10:47   #14 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
one set taken by owner doesn't want to loose his data,done with xyz tool
i also got this one with PRIVACY PASSWORD CANT READ USERLOCKS
LOCKED DUMP HERE https://www.4shared.com/rar/ZAjUR2jf...ON_N25W64.html
Help me to get its password without formating
LOGS
Operation : Read Flash [ v1.01 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [MICRON] : N25W64 : 0x00800000 [ 8MiB ]
Read Ok!
Saved to : C:\Users\UNIXX\Desktop\FLASH_DUMP MICRON N25W64.bin
Done!
READ USERLOCK HERE
You are free to call it HIJACKING OR SOMETHING ELSE
The Following User Says Thank You to Kirumira For This Useful Post:
Old 12-18-2017, 15:37   #15 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
waiting for reply sirr
Page generated in 0.27120 seconds with 8 queries
