please help plz i want backup from handset wich had this firmware BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN br koonfedg |
flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Cect-N95_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07_16m_ En_Cn_Cn_Ar.B0M.bin |
the prob. is the corrupted eeprom can u help me in this case please, i dont have any backup |
i mean damage eeprom becoz of this log 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00FC0000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:00FC0000-00FFFFFF |
hello! i adviced you a flash file. did you try to flash it? |
yes i did but it still dead |
hello! make format FFS comple if phone still dead- time to look for hardware error |
1) Try to long press the power button (Long press above 1min) 2) After long press phone is not on then check the phone in hardware. Post result. :p :D ;) |
