10-03-2010, 08:28 | #1 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1325652 Status: Offline Thanks Meter: 1 | Please Help..Cant Flashing Nexian G801 with Infinity process done but the phone still died here a log: COM5 [VCP0] selected module v3.60 Device: Nexian-NX-G801 Checking data, wait... Action: write flash NAND write: Firmware Nexian-NX-G801_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_15__fullflash_20100927-105932.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_15.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521.MP.F1.ID.XL.07.15 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_15.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_15.BIN project-id: E521.MP.F1.ID.XL.07.15, 48B7A4F5 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_15.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_15.BIN_F5A4B748].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._TINNO35_09A _PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_XL_07_15.BIN _F5A4B748_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_15.BIN_F5A4B748].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_15.BIN_F5A4B748_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_15.BIN_F5A4B748 Unknown firmware found (v.3.60, database date: 23.09.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_15.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 10 min 7 sec Remove/Install battery now ! can everyone explain this..where my wrong thanx b4 BR |
The Following User Says Thank You to raja cellular For This Useful Post: |
10-03-2010, 18:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, You have to flash phone with file from support area but not with your own backup (that was read from dead phone). |
10-05-2010, 05:46 | #3 (permalink) |
Member: 1325652 Status: Offline Thanks Meter: 1 | COM5 [VCP0] selected module v3.61 Device: Nexian-NX-G801 Checking data, wait... Action: write flash NAND write: Firmware Nexian-NX-G801_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_17_2010-03-01_Exelcom_En_Id.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521.MP.F1.ID.XL.07.17 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN project-id: E521.MP.F1.ID.XL.07.17, 6C19AB52 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._TINNO35_09A _PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_XL_07_17.BIN _52AB196C_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_17.BIN_52AB196C_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C Unknown firmware found (v.3.61, database date: 02.09.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 6 min 56 sec Remove/Install battery now ! i have reflash with flash file from support but, still error like this sir.... (reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN project-id: E521.MP.F1.ID.XL.07.17, 6C19AB52 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._TINNO35_09A _PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_XL_07_17.BIN _52AB196C_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_17.BIN_52AB196C_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN_52AB196C Unknown firmware found (v.3.61, database date: 02.09.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware ) any idea? thx BR |
10-05-2010, 05:46 | #4 (permalink) |
10-07-2010, 16:11 | #5 (permalink) |
Member: 1325652 Status: Offline Thanks Meter: 1 | PROBLEM SOLVED!! flash with latest version of MModule Thx very Much Infinity for the GREAT SUPPORT ==== [10/7/2010 9:58:54 PM] ==== COM5 [VCP0] selected module v3.62 Device: Nexian-NX-G801 Checking data, wait... Action: write flash NAND write: Firmware Nexian-NX-G801_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _ID_XL_07_17_2010-03-01_Exelcom_En_Id.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521.MP.F1.ID.XL.07.17 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_ID_X L_07_17.BIN project-id: E521.MP.F1.ID.XL.07.17, 6C19AB52 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_ID_ XL_07_17.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 6 min 57 sec Remove/Install battery now ! Action: read/check information Model: Nexian-NX-G801 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: TINNO35_09A_HW Software version: E521.MP.F1.ID.XL.07. Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: " imei-2: " imei-3: " Finished, time used: 19 sec Remove/Install battery now ! BR Raja Cellular Indonesian |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
