05-06-2018, 18:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | please help condor p8 pro secured boot 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! *********************************** i tryed many da but no success and with button down Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 150 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! ********************************* |
05-07-2018, 04:32 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello @dadarko; your problem solved or not if not have solution without da file you can connect phone and remove FRP Good Luck |
The Following User Says Thank You to gracy_elec For This Useful Post: |
05-07-2018, 05:35 | #3 (permalink) | |
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
hello this phone is new model and i want the da to read firmware, this phone is from a shop of my friend, and his firmware don't exist yet in condor software site, how i can remove frp without da please ? | |
05-07-2018, 16:40 | #4 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | @gracy_elec hello think you for your help i tryed all staps but no success this phone boot 2 times first in mtk usb port after deconnect and boot again in mediatek preloader vcom (android) please what i can do ? |
07-26-2018, 01:25 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 |
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
