09-21-2020, 11:04 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | How to reset frp of infinix x-625c ? Waiting for kind replies ,,, |
09-21-2020, 15:41 | #2 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Anybody or kind supporter can give me the DA file for infinix X-625C ? need only valid link without password ,,,,if anybody can help in this regard ... |
09-21-2020, 15:52 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Select model infinix, New Sec Reset frp in Preloader mood.. Other one Select Tecno, Lb6 Reset frp. Post the result. |
The Following User Says Thank You to GSM SINDH For This Useful Post: |
09-21-2020, 18:01 | #5 (permalink) | |
Freak Poster Join Date: May 2020 Location: Globe
Member: 2955840 Status: Offline Thanks Meter: 83 | Quote:
The Following User Says Thank You to Chijohn For This Useful Post: |
09-22-2020, 07:21 | #8 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Know phone is DEAD ,,,will be ok if i will get DA file for said model ,,,anybody there to understand and help me ,,, here is log file -: Card found : D11790A9 , v0145 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.15 Load IDBase v729152 Ok! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.15 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
09-22-2020, 08:04 | #10 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | baba i will be realy gratefull you ,,if you could kindly give me DA file for said model ,,,this forum is made with concept to learn and help each other .... but remember sir ,,,file should not be password protect,,, i have download 3 DA file since tomorrow from different link but all are password protected ,,,, hope you will not feel it. waiting for your knd help. |
09-22-2020, 17:20 | #12 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | If you follow these methods so really no need any kind of da files because infinity team already made everything in software as I said you above You can read again here In main platform Select model infinix, New Sec Reset frp in Preloader mood.. Other one Select Tecno, Lb6, or secure v2 Reset frp. And Post the result. |
09-22-2020, 17:31 | #13 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Karachi (PAKISTAN)
Member: 2609063 Status: Offline Thanks Meter: 103 | okie fine... here is your DA how to use, paste in TECNO folder location.... C:\InfinityBox\CM2MT2\boot\Tecno now open MT2 tool and click on TECNO DA... you will find last bottom X625C just select it and do what you want. Enjoy. link is here. X625C without password |
The Following 3 Users Say Thank You to babarmughal For This Useful Post: |
09-23-2020, 06:57 | #15 (permalink) | |
Member: 566122 Status: Offline Thanks Meter: 322 | Quote:
The Following User Says Thank You to aminnovelty For This Useful Post: |
