09-24-2020, 07:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: india
Member: 2035093 Status: Offline Sonork: 100-1577177 Thanks Meter: 100 | please help infinity team. 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 58 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A13549F28043 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xDE2349BC5035B3C041777D237387BE19 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micormax ProdName : Micromax A115 ProdModel : Micromax A115 Device : A115 AndroidVer: 4.1.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.MP.V1.19 MODEM : BaseBand : MT6577_S00_MAUI_11AMD_W12_22_SP_V26 Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 58 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A13549F28043 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xDE2349BC5035B3C041777D237387BE19 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Error! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
