11-02-2015, 14:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | World 1st Lava Iris X8 Monkey Test And To Many Virus Remove Done By Singel Click! Code: Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051375853414201CF3AE641122D DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 15010051375853414201CF3AE641122D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 18 Removing infected files and scripts ... SmartAV Report : Removed 18 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:25 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
03-05-2016, 11:54 | #2 (permalink) |
Insane Poster Join Date: May 2013
Member: 1946652 Status: Offline Thanks Meter: 14 | Port : ADB Interface Baud Rate : Not Applicable Device : Android Operation : Anti-Malware Searching for Device... Found Model : irisX8 Version : 4.4.2 Hardware : mt6592 Baseband : MOLY.WR8.W1315.MD.WG.MP.V34.P8, 2014/12/10 16:51 SIM Card : ABSENT CPU : armeabi-v7a Type : GSM IMEI(1) : 911433801597551 Type : GSM IMEI(2) : 911433801648057 Checking Root Access... OK Root : Rooted Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found : 9 Removing Malware/Suspicious Data... Done Rebooting Device... OK Operation Finished. Elapsed Time: 00:18 Module Ver. [1.4.1] Log Saved to Logs\160305_162005.log ONE CLICK REMOVE MONKEY VIRUS BY UMT. THANKS TEAM |
