03-10-2016, 09:56 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | how to write phone contact that read with cm2 Operation : Read UserData [ v1.42 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048603A21DD431D3 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048603A21DD431D3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : AB92A7BBE47D0666F2AAD2F6751A04C7 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Step #2 Read Ok, PhoneBook records extracted : 1699 TXT Saved to : F:\MT6582_PhoneBook.txt Write : 1699 CSV Saved to : F:\MT6582_PhoneBook.csv VCF Saved to : F:\MT6582_PhoneBook.vcf Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
03-10-2016, 15:34 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Why not google about it? CM2 made STANDARD files, which can be uses whatewer you want. Just google. All explained even with pictures how move hand by X and Y axis to choose/press need button. |
