11-24-2007, 09:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: indonesia Age: 39
Member: 531344 Status: Offline Thanks Meter: 23 | Please help with this Phone Mito 288GG please help me,i confused work with this phone. i think i want to flash 2nd cpu,but i search in main support but there no file. this is file back up for 2nd cpu "E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN] _20071123-133537.B0M.bin" |
11-26-2007, 13:28 | #3 (permalink) |
Member: 531344 Status: Offline Thanks Meter: 23 | yes i do sir i formated cpu 1 & cpu 2 but still same sir,can you tell me how to change imei in 2nd cpu,"i connect Rx-b & Tx-b and connect ground" but phone can not change imei in cpu 2nd why???.i have done to change imei in cpu 1st and i don't know how to change imei in 2nd cpu. can you tell me?? |
05-12-2008, 20:52 | #4 (permalink) | |
Insane Poster Join Date: May 2008 Location: Yogyakarta Indonesia
Member: 771036 Status: Offline Thanks Meter: 10 | i've problem too Quote:
helo Team INFI i've problem like liem_james..so,i need solution with this problem cannot read 1 sim.I try to reflash firmware n eeprom still problem. Need idea for this. thanks before | |
05-13-2008, 22:25 | #6 (permalink) |
Member: 771036 Status: Offline Thanks Meter: 10 | thanks for reply .. For format both i do that and for restore both imei's i don't try. but please i need step by step tutor for restore both imei's Thanks Before |
07-03-2009, 13:37 | #8 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | hello infinity team, i need help on how to format the 2nd CPU,it is mito 288gg, same problem.. tried to find way to get infinity detect the 2nd CPU, but i can't. It detected mt6226 cpu all the time. please help me to find way to make infinity detect the 2nd cpu.thx br, |
07-04-2009, 02:54 | #10 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | umm,would you please show me how to disable the first cpu pinouts/where its place? Do i need to use pinouts from pcb, not from charger connector, in order to disable first cpu pinouts? or maybe i should take some components to disable cpu pinouts? br, |
07-04-2009, 13:18 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! in pinfinder advanced settings you can see all pins which is used in search. by unmarking any of them you can exclude it in future search. unmark first MCU pins and repeat search |
07-07-2009, 03:20 | #12 (permalink) | |
Member: 911645 Status: Offline Thanks Meter: 19 | Quote:
1st search i got. rx:7, tx:9 -->mt6226, then i unticked those pins, and tried another search, but still infinity didn't detect the 2nd cpu. i'd tried to choose both mt62xx (autodetect) and mt:6205,.....6230 in cpu option. is there another setting options that i missed? i think there's another option that i missed, that infinity didn't detect the 2nd cpu? thk u for ur help, been great help 4 me | |
07-08-2009, 20:11 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 6, 10 can be needed pins. you can check voltage on them, if it is betweek 2,7-2,9 volts- then 100% they are |
09-17-2009, 18:21 | #15 (permalink) |
Freak Poster Join Date: Sep 2004 Location: BG, Sofia Age: 47
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | hello Infinity Team my problem is like liem_james. I need solution for this problem - cannot read 2 nd sim. I try to reflash firmware of both CPU-s - still problem, format both CPU-s - still problem. Also after flash i change IMEI but IMEI 2 is not changed . If i try to use 2nd SIM phone "says" "Error!" Need idea for this. thanks before |
Please help with this BLACKBERRY. | eskerra | PolarBox 3 | 3 | 02-12-2008 01:33 |
please help with this n-gage | Byte | Nokia Hardware & Hardware Repair | 4 | 12-07-2006 21:46 |
Please Help With This Type Of Phone | Mansoor | Various | 0 | 10-18-2005 10:34 |
Please help with this. D500 internal speaker | The Repair Shop | Samsung Hardware Repair | 0 | 08-01-2005 16:23 |
