12-21-2019, 17:51 | #1 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Please Help Team Or Any Expert And Every Da With 6739 Brom Mode PL Mode Did Everything But No Luck Here Is Log Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+ARB BROM : BOOTROM MODE : Wiko : SEC_6739 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V1: 0000 0000 [0001] BROM : SOCID : 0054348BC8144C4F2654162FDB2AC7F0DEE8568985E0507B04 E1F4C398D76767 AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v4 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! |
12-22-2019, 13:55 | #5 (permalink) |
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Problem Solved Thanx to Mr Kamal_Singla Sir Close This Thread http://forum.gsmhosting.com/vbb/f296...-done-2750547/ |
