01-20-2010, 16:00 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: FRANCE Age: 42
Member: 105560 Status: Offline Thanks Meter: 8 | Please help zte gx760 Code: COM39 [VCP1] selected module v3.03 Action: read unlock codes unlock method: read codes Model: Aiko-17G Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 8 sec Remove/Install battery now ! |
01-20-2010, 16:32 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | Quote:
wrong model slected... | |
The Following 2 Users Say Thank You to chimed09 For This Useful Post: |
01-20-2010, 16:59 | #3 (permalink) |
Member: 105560 Status: Offline Thanks Meter: 8 | Code: COM39 [VCP0] selected module v3.03 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 4 sec Remove/Install battery now ! |
01-20-2010, 17:06 | #4 (permalink) |
Member: 105560 Status: Offline Thanks Meter: 8 | Code: COM39 [VCP0] selected module v3.03 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 9600 autodetect Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 2 sec Remove/Install battery now ! |
01-20-2010, 20:50 | #6 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | |
01-21-2010, 22:56 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @leboss It looks like you have used wrong cable. Please, double check your cable, see Infinity-Box Shell for detailed information about X761 cable pinout. |
Please help Zte F233 not unlocked | KhalIman | FuriousGold | 13 | 06-06-2011 08:05 |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
zte gx760 unlock by code help needed please[ANSWERED & SOLVED] | simlock | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 7 | 02-10-2010 03:24 |
infinity and zte gx760 | unlocklleida | Infinity-Box | 1 | 09-11-2009 23:55 |
zte gx760 | jutsi | Various CDMA/TDMA Cell Phones | 0 | 07-09-2009 17:58 |
