Old 02-17-2009, 13:29   #1 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
S621 flash with simfree file but DEAD
flash the phone with simfree flash file but after flash phone dead
COM4 [VCP0] selected
module v2.65
Device: Alcatel-S621X, S621A
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001003:A005
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22422200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.22095 81D.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_26DFC24B].rpl
identification#1 detection finished
device-id: 2209581D
identification#1 protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, B43D20D9
ffs offset/size: 01020000/00FE0000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 35199002024450
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_2209581D_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_26DFC24B_20090217-165830.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD54BM02
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_2209581D_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_26DFC24B_20090217-171144.B0X.bin
Finished, time used: 832 sec
Remove/Install battery now !
AND THEN REPAIR SECURITY AREA NOW FONE LIVE AND UNLOCK DONE
module v2.65
Action: repair security area
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001003:A005
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
security area (code #1) is damaged, recalculation required
device-id: 2209581D
ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF
Write: security area (code #1)
security area (code #1) fixed
sim-lock status: disabled
done
done
Write ...
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_2209581D_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090217-172150.B0X.bin
Finished, time used: 89 sec
The Following User Says Thank You to zahid_gsm For This Useful Post:
i flashed s520x with simfree file phone white display check logs here observer123 Infinity-Box 1 09-09-2009 20:16
V670 after flash with SIMFREE is dead best_s_gsm Infinity-Box 4 05-08-2009 15:01
CID52 phone but need to flash with CID49 files. Can it be done? .ALDAGSM. Cruiser Suite 3 03-25-2008 17:41
t237 dead after flashing with t230 file glicos Cruiser Suite 2 11-01-2005 06:42
MC60 dead after flash with fubu-file Winner58 Siemens-Benq RingTones and WallPapers 24 04-09-2004 14:59
Page generated in 0.14262 seconds with 9 queries
