09-22-2018, 16:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Please How to revive this tecno LA7? Below is error low; Card found : B25B7C49 , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Created by Infinity-Box (c) 2018 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : O11019 Display ID : LA7-H393A-O-180423V90 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-03-05 Build Time : 1524467957 Product Brand : TECNO Product Manfct : TECNO MOBILE LIMITED Product Model : TECNO LA7 Product Device : TECNO-LA7 Product Name : H393 Product Info : TECNO-LA7 Product Board : la7_h393 Board Platform : mt6739 Preloader [HW DEV] Info : EMI : DEV : EMI : SRC : EMI : CNT : 0000 Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :19 [FL] : Set : preloader_la7_h393.bin [FL] : Set : preloader_la7_h393.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x74A0A910 [ 1.82 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
09-25-2018, 21:00 | #7 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Biafra
Member: 2128067 Status: Offline Thanks Meter: 16 | |
10-04-2018, 18:00 | #8 (permalink) |
Member: 576282 Status: Offline Thanks Meter: 145 | I have even use the factory signed firmware and is still like that, please how to solve it? Logs below; Card found : B25B7C49 , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Preloader [HW DEV] Info : EMI : DEV : EMI : SRC : EMI : CNT : 0000 Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :20 [FL] : Set : preloader_la7_h393.bin [FL] : Set : preloader_la7_h393.bin [FL] : Set : recovery-verified.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : mcupmfw-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : loader_ext-verified.img [FL] : Set : loader_ext-verified.img [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : odmdtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xB0E07258 [ 2.76 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :20 [FL] : Set : preloader_la7_h393.bin [FL] : Set : preloader_la7_h393.bin [FL] : Set : recovery-verified.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : mcupmfw-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : loader_ext-verified.img [FL] : Set : loader_ext-verified.img [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : odmdtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xB0E07258 [ 2.76 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
10-04-2018, 18:12 | #9 (permalink) |
Member: 576282 Status: Offline Thanks Meter: 145 | What actually happened is that I download a stock firmware from https://forum.hovatek.com and the file after extract did not have "scatter" file inside then I copy the "MT6739_Android_scatter" from the folder of the one I read with cm2 and paste on the stock firmware folder and flash it with it and it start giving this error. Please I believe this explanation will help out for you guys to give me solution for this. Am waiting, please help me out! Thanks! |
10-05-2018, 10:33 | #10 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
Is there no one to help me on this, am having issue with the owner of this phone now, please somebody help me out! | |
10-05-2018, 12:18 | #12 (permalink) |
Member: 576282 Status: Offline Thanks Meter: 145 | You said I should Look for signed firmware and re-flash the phone with it, and I have bought factory signed firmware from online (since I didn't see it free ) and flashed the phone with it and still get the same error that is what I said on the previous post above. Please does it mean the flashship has been corrupt because of the action I explained above? So please help me out! |
10-05-2018, 12:28 | #13 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
I am not the owner of the site but I have also bought firmware from them which worked perfectly. https://www.dst-gsm.com.ng/2018/08/t...ctory.html?m=1 | |
10-05-2018, 17:39 | #15 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 568259 Status: Offline Thanks Meter: 52 | Plz chek this link i hope it will help you to fix your phone https://flashfirmwarefile.com/downlo...re-flash-file/ Envoyé de mon SM-A510F en utilisant Tapatalk |
