06-15-2011, 14:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Location: morocco
Member: 27112 Status: Offline Thanks Meter: 10 | please infinity COM4 [VCP0] selected module v3.92 Device: Vodafone-547 Checking data, wait... Action: write flash NAND write: Firmware ZTE-G-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ ENG_EN_P107A3V1_0_4B05_En_Fr_Es_Orange-Miami.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 636F6D6D7A65726F202863296C617374 warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... error: can not write flash (0): 0C18:S_DA_NFB_BLOCK_0_IS_BAD error: last error: 0C18:S_DA_NFB_BLOCK_0_IS_BAD Disconnect... done Finished, time used: 42 sec Remove/Install battery now ! thanks |
06-15-2011, 16:17 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | please, check operation log again: Code: error: can not write flash (0): 0C18:S_DA_NFB_BLOCK_0_IS_BAD error: last error: 0C18:S_DA_NFB_BLOCK_0_IS_BAD |
06-15-2011, 19:39 | #10 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | try this mathode 1-erase whole flash chip 2-write original backup file if have 3-if no have original backup find same working phone and read full flash 4-write readed good flash file and post result |
