01-16-2009, 17:17 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
LG KP202 Unlock advice | virtue | HWK | 2 | 06-26-2008 11:07 |
<< LG KP202 Unlocking Success! >> | kasamiko | Infinity-Box | 3 | 01-02-2008 16:17 |
LG kp202 unlock | LIONMOBILE | LG | 3 | 12-15-2007 07:38 |
LG kp202 unlock | LIONMOBILE | ULT PRO | 2 | 12-05-2007 14:44 |
Compatible model selection for LG KP202 unlock | virtue | LG | 1 | 08-24-2007 06:43 |
