04-30-2009, 19:03 | #2 (permalink) | |
Double check your cable, probably you need to swap Rx <-> Tx. If problem still exist post here operation log so we will be able to understand what is wrong. | |
05-01-2009, 01:55 | #3 (permalink) |
Junior Member Join Date: Jul 2007
Member: 549150 Status: Offline Thanks Meter: 3 | yes i did it i managed to unlock this phone there is only one little thing pinout it's wronggg the right pinout for zte a37 is key board top 1............18 8-ground 13-box tx 14 box rx the only thing now is that i have to change the ftdi chip due to wrong conection here is full log COM1 [Serial0] selected module v1.32 Device: ZTE-A37 Checking data, wait... Action: unlock Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC257E25062501:70E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356624017560637 file saved: E:\Program Files\InfinityBox\AModule\eeprom_356624017560637_Z TE-A37_20090430-184826.98E.bin Check flash Done Check space ... file saved: E:\Program Files\InfinityBox\AModule\_eeprom-calibration_20090430-184837.98E.bin file saved: E:\Program Files\InfinityBox\AModule\_eeprom-ffs_20090430-184919.98E.bin reading lock-area-2... file saved: E:\Program Files\InfinityBox\AModule\lock-area-2_ZTE-A37_20090430-184934.98E.bin Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 282 sec Remove/Install battery now ! ill try to find the right pinout for coral 500 8 pin mini usb now thanks infinity team |
The Following User Says Thank You to devil6684 For This Useful Post: |
05-01-2009, 07:55 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Are you sure that GND for A37 is pin 8 but not pin 11 ? Please, double check it. Also it may be that pin 8 and pin 11 both connected to GND. Please, check it if you still have phone on hands. |
05-01-2009, 22:46 | #5 (permalink) |
Member: 549150 Status: Offline Thanks Meter: 3 | yes sir pin 8 works for me ill make another log but first i have a problem i have 5 different zte to unlock and the main in all of them got the bands deactivated so i tried to flash it with the files in support area but every time i try to flash the program flashes the phone but when it's almost finished the program restart connecting again |
Can't unlock zte-a36+??????? | sky_finder | Infinity-Box | 13 | 05-19-2011 07:03 |
Can't unlock ZTE-G X760! [Too old already supported] | GSMBlade | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 22 | 04-23-2011 20:41 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 7 | 05-27-2010 10:17 |
can't unlock ZTE MD2 | sajib_ngage | VygisToolbox | 0 | 01-18-2010 10:23 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 1 | 09-28-2009 17:24 |
