03-31-2009, 17:50 | #1 (permalink) |
Insane Poster Join Date: Oct 2008
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | 5310 RM-217 no flash file from support site I need your assistance with this unit 5310 (RM-217). The phone is totally dead and I can't find the exact flash file for this one. Would you please help with this one... Below are the steps I already tried: 1. Use safe format and there is an error 2. Use the complete format and it completed the process. The problem now is, the phone powers on for a few seconds and it only shows the Nokia logo then it shuts down and you cannot power the unit again. You need to repeat the process again then phone do exactly the same thing. I tried using the repair feature to no avail. 3. Downloaded 4 different flash files from the support site and flash it one at a time to the phone. The unit is alive again but with white screen. I concluded that the flash files are not compatible with the unit. Here is the exact filename of the flash file. MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27 The file has a 9.10MB of filesize. The flash files from the support site have different filesize. Therefore, I concluded they are not compatible with this unit. I also want to ask the help of other techs who have a good flash file for this unit I just need it badly. Thank you in advance for all of your support. |
03-31-2009, 21:44 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! you must tell us phone Original software version. for this you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone (first format FFS) date/time stamp can also be helpfull in finding it there you will see Original software version. post it here |
04-01-2009, 16:31 | #3 (permalink) |
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | Hi! Below is the operation log. I think this is the original software version of the unit and the firmware is not yet available from the support area. Hope it helps. Thank you again in adv for your help... ver. sw 1: MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27.BIN ver. sw 2: GF5.06B.W07.08.MP.V27, D2F5D14B Operation Log: COM7 [VCP0] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6B03:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E853CCE8.[MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27.BIN_B42E0A2D].rpl ==================== New firmware detected (v.2.79, database date: unknown): MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: E853CCE8 identification#1 protocol ver: 04 ver. sw 1: MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27.BIN ver. sw 2: GF5.06B.W07.08.MP.V27, D2F5D14B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_E853CCE8_MT6225_06B_PCB01_GPRS_MT6225_S0 0.GF5_06B_W07_08_MP_V27.BIN_B42E0A2D_20090328-044250.B0X.bin Finished, time used: 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-02-2009, 23:31 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! try following file: [bin] flashfiles/ChineseMiracle/_MT6225/MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27__Nokia-5310-RH-37_16m_En_Id_Vn_Cn.B0M.bin |
04-03-2009, 15:54 | #5 (permalink) |
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | Hi! I tried the four flash files below from the support area including the one you have suggested to no avail. The unit will power on but only white screen will appear on its lcd... Any other suggestion? Do you want me to send the origial flash file to [email protected] so they can check on the file and make some repair that will help us for future use? MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27_16m_En_Ru_Fr_Th_Ar.B0M.bin MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27__Nokia-5310_16m_En_Ru_Fr_Th_Ar.B0M.bin MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27__Nokia-5310-RH-37_16m_En_Id_Vn_Cn.B0M.bin MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27__Nokia-5310XM_16m_En_Ru_Fr_Th_Ar.B0M.bin |
04-05-2009, 10:16 | #6 (permalink) |
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | Hi, here is the original flash file of 5310 RM-217 that is having a problem. You can now check on it what's causing the problem. Thanks in advance. http://www.mediafire.com/?4yywyd4enoy http://www.mediafire.com/file/4yywyd4enoy/flash[MT6225_06B_PCB01_GPRS_MT6225_S00.GF5_06B_W07_08_MP _V27.BIN]_20090327-123241.B0M.bin |
04-05-2009, 11:49 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! unfortunately, we can not repair faulty firmware files. you must find same working phone and read out backup use it to restore your faulty set. unfortunately, this is the only left way, if you tried all flash files from support |
04-07-2009, 16:54 | #11 (permalink) |
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | Hi! I have managed to get a backup file in BIN format. Would you please convert it to BOM.BIN format so I can try it in Infinity? Thanks in adv and heres the link where you can download the file... http://www.mediafire.com/?sharekey=8...4e75f6e8ebb871 |
04-07-2009, 20:32 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Your file can not be used due to 2 reasons: 1. it was read from damaged phone, data inside firmware is damaged 2. this type of firmware should be read with Infinity-Box only, we can not create good flash file from backup that was made with other software. |
04-08-2009, 15:38 | #13 (permalink) |
Member: 882459 Status: Offline Sonork: EngrRML Thanks Meter: 9 | Thanks for that info. I'll keep that in mind. So, I guess I'll stick with the first option. Wait for the same unit, create a back-up file and try it on the dead phone. Thanks again. |
06-11-2009, 09:29 | #14 (permalink) |
Junior Member Join Date: Mar 2008
Member: 735025 Status: Offline Thanks Meter: 0 | chinese miracle flash file to plain bin file (not encrypted or packed) hello infinity , i have a question , i have infiniy box with language pack editor . with chinese miracle i read flash files frpm phones. is there a way i can convert the flash bin files to plain bin files because infinity encrypts bin flash and i cant read with hex editor. thank you |
06-11-2009, 14:38 | #15 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | @InfinitySupport Here is fully working 16MB .BIN file of above mentioned phone. http://www.4shared.com/file/11119086...08_MP_V27.html Please convert it to Infinity-Box supported format and upload it to support site. Best Regards! yawarniazi |
6300 dual sim.Rm 217 new flash file for infinity | biochemistali | Infinity-Box | 5 | 08-26-2009 14:30 |
there is no bb5 flash file on support site | neeraj1st | MT-BOX | 9 | 03-02-2009 09:11 |
I don't download files from support site!!!!! | Umbabaraumba | Multi-Box | 4 | 08-13-2007 08:08 |
I cant download any file from support site!!!!!!!!!!!!!!!! | GSMLover2010 | DreamBox | 4 | 02-07-2007 20:07 |
please any one know can i flash W810c with flash file from support area or no | gsm4libya | Cruiser Suite | 1 | 05-14-2006 17:03 |
