11-20-2007, 08:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | pleese help bluetooth S800+ dual sim need pinout 8 pin bluetooth S800+ dual sim need pinout 8 pin |
11-20-2007, 09:02 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
06-14-2008, 04:00 | #3 (permalink) |
Freak Poster Join Date: Oct 2006 Location: midnapur west
Member: 378776 Status: Offline Thanks Meter: 20 | pls help me bluetooth S800+ dual sims restart problem i have infity pinfinder i try to connecting but msg show it software version: 1.10 cable type: 2x5 (L10B) platform: MT6205, MT6217-MT6228, MT6230 searching adapter at COM4... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed error: boot initialization step-2 failed: D0 error: boot initialization step-3 failed: 8D 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step-2 failed: 58 error: boot initialization step-2 failed: 70 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 47 sec Power Off ! Power On ! |
06-14-2008, 14:50 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! does phone is able to power On from box power? If yes, but phone pinout still can't be found- looks like this phone does not hold tx/rx in system connector, but in test points. Open phone, check which MCU is used and also look for marked or unmarked test points |
06-26-2008, 10:37 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If so, you need to make small modifications/improvements for your Unibox. Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 19: Automatic pinout detection: Troubleshooting |
06-26-2008, 10:39 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if phone can not be powered from box power- you must modify a little your box. in pinfinder user manual you will see how to remove Diode from main infinity box to make it deliver more power to pinfinder. also on some phone models capacitor must be set on pinfinder output |
E71 TV-DUAL SIM need help how to connect? | titanoel | SpiderMan | 5 | 06-29-2010 14:58 |
6300 dual sim need pinout :( | KING_RadZ | Infinity-Box | 17 | 11-22-2009 01:50 |
6300 dual sim need pin out............ | anaklupa | Chinese Models & Cloned Phones | 6 | 04-11-2009 17:39 |
6120 -rm217 dual sim ..need pinout | kevin182029 | Infinity-Box | 4 | 02-19-2009 06:55 |
help bluetooth S800+ dual sim need pinout 8 pin | SHOEB AHMED | Chinese Cocktail | 2 | 11-20-2007 12:14 |
