plese help infinty team how to proceass of flashing uasha -lexus 800b please help |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset settiong to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
