Old 02-05-2010, 19:05   #1 (permalink)
Member: 1146038
Thanks Meter: 196
pls help infinity team... pls
modal : n83 sop-cn " this is modal name "
this link is flash file link for support area :-
http://server1.infinity-box.biz/down..._En_Cn.B0M.bin
my orginal flash file name : DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114 __fullflash_20100205-220643.B0M.bin
my orginal eeprom file name :
DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114 __ffs_20100205-220904.B0E.bin
pls slove my problam : - this is my problam
after setting imei in this phone i can't write imei in this phone , i also tried mode-1 , mode-2, mode-3 but it was in vain and imei was 000000000000000 i downlode the file from support area and again flased after that imai was invalid i wrote new imei it was successful, i took read general inf. in seite of that imei remain 000000000000000 .....
pls help me .....
Old 02-05-2010, 20:21   #2 (permalink)
Member: 148515
Thanks Meter: 19,347
hello!
make "erase whole flash" operation.
flash your phone with that file again.
power on it, power off.
next change IMEI with method -1
post here log and result
remmember: some phones must be rebooted for getting new IMEI active
Old 02-06-2010, 07:05   #3 (permalink)
Member: 1146038
Thanks Meter: 196
COM3 [VCP0] selected
module  v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: erase whole flash chip
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:D103:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114.BIN
project-id: Q68_Q68S_L114, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E40000
detecting ffs/eeprom size...
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114__ffs_20100206-111023.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
chip formatting...
Erase: chip 1 of 1
Finalization Done
Finished, time used: 3 min 49 sec
Remove/Install battery now !
flash operation.
module  v3.08
Action: write flash
"smart write" active
write: Firmware
DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.Q68_Q68S_L114_16m_En_Cn.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
flash: 98004900000002:FFFFFF00000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
standard ffs/eeprom offset assigned: 00E00000
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
standard ffs/eeprom address selected by user
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100206-111525.B0E.bin
====>  Write ...
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 13 min 22 sec
read gernal information
 Action: read/check information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: DEWAV25_GEMINI_HW
Software version: Q68_Q68S_L114"
Software date: 2006.06.14
Barcode: Q68XA889B200566                                  PP     PPPP10P
imei-1: 350680200018864
imei-2: 350680200018864
imei-3: 350680200018864
Finished, time used: 5 sec
repair block
Action: "repair imei"
Connecting, wait...
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 352009024623956
verification Ok
Connecting, wait...
now how to slove pls help.....
Old 02-06-2010, 21:42   #4 (permalink)
Member: 148515
hello!
you restered phone and still same IMEI?
Old 02-07-2010, 08:45   #5 (permalink)
Member: 1146038
Thanks Meter: 196
hello!
yes..... sir now how to slove pls help..........
Old 02-08-2010, 08:34   #6 (permalink)
Member: 148515
hello!
let me know full phone model and software version.
i will try to find it here and do some tests
Old 02-10-2010, 09:16   #7 (permalink)
Member: 1146038
Thanks Meter: 196
nothing more info hear sorry sir .....
The Following User Says Thank You to @@@___@@@ For This Useful Post:
Old 02-11-2010, 16:59   #8 (permalink)
Member: 1146038
Thanks Meter: 196
so now waiting for next update sir......?
Old 02-13-2010, 12:38   #9 (permalink)
Member: 1146038
Thanks Meter: 196
pls tell me somthing sir pls.......
Old 02-13-2010, 16:40   #10 (permalink)
Member: 1146038
Thanks Meter: 196
hello sir
one moor info to sir most lee set show imei *#06#
but
this set show imei *#06# & *#07#
one moor press #08# show " info 123456712345 "
& set on - off and show one massage " no tts file " so......
pls help me fast sir....
Old 02-14-2010, 09:43   #11 (permalink)
Member: 148515
hello!
try to change IMEI with option "default IMEI inside firmware"
let see what result we will get
Old 02-23-2010, 17:48   #12 (permalink)
Member: 1146038
Thanks Meter: 196
hello!
i will try but same result ...... use latest ver...
Old 02-23-2010, 21:55   #13 (permalink)
Member: 148515
hello!
post here log of IMEI change inside firmware
Old 03-17-2010, 13:36   #14 (permalink)
Member: 1146038
Thanks Meter: 196
one moor set problam same
Loading data, wait...
[Infinity Box] Chinese Miracle v3.10
smart-card: connected
S/N: 1B56:0116
Wait...
Done
Connecting, wait...
Hardware version: AT+EGMR=0,0
Hardware version: MT6223, E05
Software version: IWIT23_08A_HW"
Software date: H610N_QCIF
Barcode: 2000.00.00
imei-1: 071001MT0123456
imei-2: 350700105577543
imei-3: 350697302707923
Finished, time used: 6 sec
inside firmware....
 COM2 [VCP0] selected
module  v3.10
imei write channel: imei #1 (default imei inside firmware)
new imei: 353923039663345
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:3C3A:000C
status: FF
Boot Done
flash: 01227E22212201:2DEA0000000000
flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb
otp offset: 00000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
it's time to stop: 2D0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
New firmware detected (v.3.10, database date: 03.03.2010):
H610N_QCIF_ML_NT_PCB01_GPRS_MT6223P_S00.H610N_QCIF_ML_NT_V_1_0_0.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: H610N_QCIF_ML_NT_PCB01_GPRS_MT6223P_S00.H610N_QCIF_ML_NT_V_1_0_0.BIN
project-id: H610N_QCIF_ML_NT_V_1.0.0, 00000000
TCL-ID is absent
standard ffs/eeprom offset confirmed: 00E00000
ffs/eeprom chip: 00
detecting ffs/eeprom structure pass 2...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
====>  Write ...
Write: imei
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 9 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
after all operation..... " invalide sim " now how to sloved ....
Old 03-17-2010, 13:52   #15 (permalink)
Member: 1146038
Thanks Meter: 196
hear is my set backup file
MEGAUPLOAD - The leading online storage and file delivery service
Need HELP INFINITY TEAM PLS smobile_2004 Infinity-Box 1 09-01-2009 17:21
pls help infinity team crackp0d Infinity-Box 6 01-11-2009 07:31
pls help infinity team lg ke 970 R@jusat Infinity-Box 6 12-01-2008 12:58
S81 unlock pls help infinity team ringtone MD S-Gold Based Phones 0 09-04-2008 10:02
cect S500 pin out. pls help infinity team HEDEF_GSM Infinity-Box 1 06-20-2007 11:55
Page generated in 0.27025 seconds with 9 queries
