Old 06-06-2016, 11:04   #1 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 700
pls pls team fix this problem
read info done
Operation : Check / Read Info [ v1.48 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 21 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : B76C1068BBD8974B33C1569E0A915366
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3700 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E
[0] : FLASH_DIE : 00C2 0025 0037 0000
[0] : FLASH_LEN : 0x00800000
INT_RAM : 0x0000D400
EXT_RAM : 0x00800000
SDS_INFO : Not exists
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
format done
Operation : Format FileSystem [ v1.48 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00700000-0x007FFFFF , LEN : 0x00100000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:23
write sequrety failed
Operation : Repair Security [ v1.48 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting Service Mode ...
Init Service mode failed, something went wrong
try other mode
1. Phone must be powered ON and WITHOUT SIM!
2. Insert USB cable. Select "COM PORT" or "MODEM" mode!
Wait for phone...
Device boot not done
Check Drivers
Try again
some time 2nd method works but now this method is not working i already test over 20 phones and find the same problem
flash mode always failed
com mode some times working
if their is not com mode option then what i do
pls fix this
you know after format mtk seq damage and must to reapire it
but i cant
Old 06-07-2016, 06:01   #2 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 119
Originally Posted by diesel6 View Post
read info done
format done
try other mode
pls fix this
but i cant
cdc drivers not installed install cdc drivers
Old 06-08-2016, 06:23   #3 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 700
how sure you are if its drivers problem then some time com port works why????
Old 06-08-2016, 09:00   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,080
Hello,
Try with new version v1.49.
Br.
Infinity Box Support Team.
Old 06-10-2016, 08:43   #5 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 700
same problem
Operation : Check / Read Info [ v1.49 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 8D54F32A8829B33B6BDB8F8004402D44
Setting...
BROM stage done
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
Done!
Elapsed: 00:00:05
Operation : Repair Security [ v1.49 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
phone has no com port now what i do next
Old 06-10-2016, 11:16   #6 (permalink)
Member: 1377097
Sonork: butterfly
Thanks Meter: 10
mtk module ok but spd module not opening
Old 06-17-2016, 14:48   #7 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 700
still not works for me
Chinese Miracle II [MTK module] v 1.50
Operation : Check / Read Info [ v1.50 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
File_Info : LEATEK50_6464_11B_PCB01_gprs_MT6250_S00.L_2233G_V1 _4_1.bin
FileVersion : L_2233G_V1.4.1
Done!
Elapsed: 00:00:17
Operation : Format FileSystem [ v1.50 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Backup exists , skip
Done!
Elapsed: 00:00:21
Operation : Repair Security [ v1.50 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
its gfive w1 4 sim phone
Old 06-17-2016, 14:56   #8 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,380
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:21
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
use CM2 DIRECT MODE
Post results
Old 06-17-2016, 15:41   #9 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 700
direct mode works thanks cm2
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Read Security data ...
Verify Security data ...
Set IMEI [0] : 868261
Set IMEI [1] : 868261
Set IMEI [2] : 86826
Set IMEI [3] : 868261
Repair
Repair done!
Done!
Elapsed: 00:00:38
The Following User Says Thank You to diesel6 For This Useful Post:
Page generated in 0.36396 seconds with 7 queries
