07-31-2016, 13:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | pls reply about that error massege phone condition dead and here is try to readinfo log : Operation : Check / Read Info [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D4330344758C7B8AD2551F3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! why this error massage ? driver problem ? battery problem ? DRAM problem ? or any others problem ? pls reply . thanks, best regards to best team of the world mahir ashab |
